Advice for stripping cerakote please ...
luethge
900D651F-CC22-47D8-9AFA-888D89734D47.jpeg 596DD2B1-FA74-41FA-B65F-7F91B908B02D.jpeg I was hoping anyone out there could give a few pointers on stripping cerakote ( hopefully without bead blasting ) . Thank you in advance , much appreciated. I’m trying to get the majority of the aged bronze off . I’ve had some luck with 800 - 1000 grit and Scotch Brite pads .
Other than beating the coating off chopping through rough bark, using a highly abrasive sanding material is about it. So either low speed (hand sanding) or high speed (air/mechanical powered) is pretty much it from what I have tried. Keep in mind that depending on how you do it, you may wind up removing a lot of CBT material as you can see starting to occur with the flatter sections in your pics.
The powdercoating is much easier to remove.
Thank you .. I think beating the coating off will be the route I take .
