bladsmth said:
You do not want a motor from some appliance like a tread mill!
I agree completely. If you really want something that will last and you don't have to be screwing with all the time, call Minarik Electric(they have them all over, or if you can't find one, contact me and I'll get some contact info for you) and get a good Leeson motor DC Variable speed motor and MM20000 series controller for it.
An oiltite/dustite NEMA 4 controller box would be best but they can get expensive.
I've used NEMA I raintight and sealed the places dust can get in with silicone, after I had it set up and adjusted properly.
Apply the silicone and let it set up, and then reassemble the can. To do it while the stuff is still soft can make a one piece unit. Don't need to ask how I know that.
It may cost a little more up front, but buy good stuff and cry only once.
I'm too poor to buy crappy tools as far as grinders, motors and related gear. It hurts too much when you have to look back at the money wasted you could have saved towards the right stuff to begin with, when the cheap stuff you paid that money for sits on the bench worthless scrap.
If you wish to go AC variable speed, or VFD as they call it, you might try this place. They can supply you with a motor and controller for a pretty good price. The AC unit is harder to setup initially, beyond that, and the fact that it can maintain better torque in certain situations, I've not used one.
http://www.dealerselectric.com/
They're right on the first page, about 2/3rds down. You can get by with slightly less HP with AC than DC. So depending on what you have plans for, a 1-1.5 would probably work fine. If you're driving a multi wheel belt grinder, I'd go the 1.5.
Good luck however you go.
