So, after lightly sanding the awful varnish off my CRKT Woods Chogan Tomahawk, and applying light stain and oil, I put the head back on the pole/haft and it stopped about an inch higher from where it was before. As you can see in the pictures, it's pretty much flush with the top of the pole/haft.
My question is do you guys think I should put in a wedge to keep the head from flying off for safety or just use it as-is until the handle needs replacing. For the moment, it's fairly tight, but it will probably loosen with use. I could also epoxy the head in place with 5 minute epoxy, and if I ever need to remove it, just either use heat and/or drill it out to replace the handle.
I do not intend to throw it and I will most likely use the tomahawk simply as a fancy camp axe.
Cheers!
Cheers!
