Yes, the lock back is pinned. The handle is formed plastic. The only way I see to disassemble the knife is to first remove the blade, which is retained with some sort of weird 6 pointed star shaped screw - maybe some poor relation to a torx? Anyway, I've got nothing that will fit it. But assuming I find some way to remove the blade, then the next thing to remove would be the lock back lever - a metal tang w/one end set against the rotating base of the blade & the other end situated in a slot formed in the butt end of the handle, & held into the handle w/a metal pin. I have no idea how to manually drive out the pin w/o wrecking the plastic handle. No doubt it was pressed into place by machine, using hundreds of pounds of pressure. Once the lock back lever is removed, the lock back spring - a length of spring steel rod - might be removable. Or it could be molded into the plastic handle. I can't tell about that until the lock back lever is removed. The knife is manufactured somewhere in China, & the stateside distributer doesn't know any more about it's construction details than I do. There are some pretty helpful people at the local Ace hardware store. Maybe I'll take it to them & see if they have any ideas. I know this is a lot of time & effort to spend on a cheap knife, but I like this size & style, and it has a handy pocket clip, which most pocket knives lack, & I got it at a "bargain" price. I guess maybe now I know why. Anyway, I'm stubborn enough that it frosts my balls to be defeated by such a simple mechanism. The Seller says this problem is "not a manufacturing defect", so I guess the Chinese have got really strong fingers?? Or perhaps this is all a secret Communist plot to destroy us "decadent Americans" w/unworkable pocket knives! I was kind of hoping one of you knife wizards would have a miracle cure for my problem, so I wouldn't need to try to take the knife apart. Guess not. . . .
