I am getting started with knive making. I got the Loveless tape and watched it about 50 times. I got the Grizzly grinder and have about 6 knives that are not worth heat treating. It looks much easier to hollow grind on the tape. I started out with ATS34 but went to 1095 on advice from Blade magazine. I can screw up 1095 much cheaper than ATS34. The last couple have started to look much more like I thought the first one would look, though, so maybe there is hope yet.
Anyway, I saw in some of the posts that some of you use 36 grit. Do you use 36 just to get to the knife outline, or are you using it to start the bevel also? I am using 60 to start with and until I get the hollow going well and have gone through a lot of belts. Do you go from 36 to 60, or something in between?
