Hello again folks!
While I'm waiting for an opportunity to shape my fixed blades, I recently started designing a simple folding lockback knife. I've had to design this within the confines of the material I ordered, for the stainless handles this is 30 x 150 x 3mm and the blade material is RWL34 with some rather generous proportions, enough for the blade and lock bar to be cut out. A friend of mine has offered to plasma-cut everything for me after I submit a final design as DXF. The lock bar will also be made of the same material hardened (professionally by a company I got in touch with thanks to the folks here at Bladeforums!) to the same level. I will reuse the spring from a different folding knife that broke, it fits nicely in the slot but it needs to be shortened down slightly. I design these things in Fusion360 and rotate the blade and lock bar to see exactly how these parts interact with one another and how much the lock bar needs to move to clear the blade and also where the spring needs to be placed. So what I have now is a fully functional plastic folding knife, the lock snaps in place when opened and it also snaps shut. I realize the design allows the blade to come into contact with the backspacer/spring holder if you raise the lock bar and push on the blade. I have a stop pin that'll be right where the sharpening choil is when the blade is closed, this should prevent the blade from hitting anything. I think the tricky part is going to get the geometry right by hand for the blade pivot area, there are a lot of precise angles and such that make it all work. Here's the design. The next picture shows you my V1 print (well, actually more like v6 or so...) while V2 was printed yesterday, since then I have a V3 with some slight adjustments to the pivot area for a better stop against the lock bar when closed. The blade is 111mm from tip to the rear of the tang. The handle is approx 120mm from tip to butt. Is there anything I need to know, or adjustments that should be made? Everything I've made here, has been done through trial and error, and some glances at other knives in this category.
