- Jul 25, 2018
Hi guys,
I need to add 10mm to a blade I made .
The joint will not be under much stress due to the way the blade will be used in the machine.
I only need to increase the depth of the blade in order for it to fit correctly in a specific part of the machine.
The mild steel will be added to the spine of the blade and only needs to be tacked.
The blade is 40mm deep so not too much buffer between the area to be welded and the actual cutting edge.
Would it be better to weld before or after HT ?
Blade is 3mm thick.
thnx
Blade is 3mm thick.
thnx
