- Sep 28, 2005
Hello all. I am starting to dabble in leather sheaths (no rivet kydex isn't for everything), and was looking for some advice on dying rawhide, as well as using it as a wrap for knife handles. I've been testing different methods of dying, including dying before wetting, after wetting and both before and after. The Feibings red leached out very quickly when put into the water (and it was dry first), the medium brown turned green in spots and the dark brown is the most OK but still looks green in some areas. Does the rawhide need to be sealed/oiled after dying to maintain the color, and is there anything you would suggest for not having the green bleed through. I have not tried an alcohol or acetone rub first but was debating trying that to see if it helped absorb more completely. So far I have applied it with a q-tip as I am working on scraps, but would probably do multiple coats or dip/soak, also depending on advice given here.
I would like to dye and wrap a caribou handle (the brown of the wrap to offset the white as well as giving it more thickness), and have heard of the shrinking properties of rawhide, so thought that it would be a good choice for a tight wrap. I was wondering how tight it would have to be to tighten well onto the antler. My thoughts here would be to dye the "lace", then wet and tighten as much as I could as I wrapped- most likely a wrap similar to a badminton raquet (I don't know any technical names). After drying to a good degree I was wanting to add some brass or black tacks that got from Lee Valley. Making a starter hole with a drill and glue/tapping them in. My thoughts were that if I tacked them as the rawhide is drying then they might stress the rawhide- ripping it or pulling the pins out slightly. Am I on the right track or off base with my assumptions?
I was also considering what to keep the wrap tight with as it dried. On my first attempt to try wrapping with wet hide I clamped the handle and hide with little spring clamps and it left a pattern on the hide. If I wrapped the caribou handle with rawhide and took some twisted wire around to hold tight it may put the pattern into the rawhide for more character, but also may be harder to apply consistently- like a quillion twisted wire but with imprints only.
I'll keep trying on my own (I am loving trying things out for fun right now- enjoying being a rookie and doing experiments)but thought I would ask those with much more experience and have been there and messed it up before me! Any direction will be appreciated.
Thank you for your time.
