- Aug 4, 2004
Today I picked up a large coal forge from a neighbor. It appears to be the first model (Cannedy-Otto) that is listed on this page: http://www.beautifuliron.com/factory.htm.
Here's a picture of the one I bought:
It came with a blower (which needs a hand crank) and this tee-shaped thing which sits beneath the firepot and catches the ash. (sorry, I'm new to this so I don't know the terminology).
Here's the problem, the cast iron forge has a crack (actually, two cracks) in it. It looks like somebody did a repair on it. Here's a picture of the crack. The other crack is similar but much, much smaller and is repaired in the same way.
I would like to know if this sort of repair will be sufficient to hold the thing together. It didn't fall apart when picking it up and transporting to my house.
I could try to braze or weld the crack. I am not sure if this would be a good idea. I'm not an experienced welder and I haven't welded cast iron before. I read a few online articles about the precautions you have to take in welding cast iron.
My neighbor told me that this forge also needs a ring which sits in the hole in the body, and the tee-shaped thing is bolted on to this ring. I was planning on making one out of 1/2" mild steel plate - would this be OK? I also need to make a grate to go over the ring, and an arm to hold the blower.
Thanks.
Thanks.
