Ok, so I finally got around to grinding the bevels on a knife on my new 2x72. First time I used a grinder for bevels (previously hand filed them). I over heated the blade in a few spots and you can see the blade turned colors and also burnt the tip of the blade off. I was using a jig and on 1 side the angle changed a bit and now the bevel looks off. I also messed up the plunge lines.
So, can I salvage this blade? The spots that got hot, will those be affected in any way? This is pre heat treatment. I figured I could regrind the point back and try to fix the plunge lines and then use a 120 grit to smooth out the side where the angle changed.
Any advice?
I will post pics if that will help.
Thanks
Any advice?
Thanks
