I've been looking at AEB-L for quite a while, and it seems very good on the paper. In Dr Larrin's heat treat datasheet, it shows that AEB-L can get up to 64 HRC while still being much tougher than D2 at 61 HRC. I have never managed to (badly) chip my D2 knives, eventhough D2 isn't very tough.
Does this means that AEB-L has high edge stability?
I watched many Shawn Houston's videos, this is how I understand edge stability, and please correct me if I'm wrong: Edge stability is having a stable edge at high hardness, this is a combination of the chemical composition, carbide size, heat treat quality, geometry,...
The saying is "geometry cuts". High hardness will lead to less deformation, but more prone to chipping. So if you can create a good geometry, and high edge stability , then the knife would cut better?
Thanks.
Thanks.
