- Apr 22, 2022
I’m not set up to profile a blade post heat treat. I’ve got an el cheapo harbor freight 1x30 belt sander and a file jig. My first AEB-L blade warped during cold treatment (dry ice and 91% isopropyl alcohol). I tried to peen the thing straight and it cracked. The good news is when I broke it the grain structure is very fine and I estimate it is 61 Rockwell. At any rate it skated with the 60 file. I made another one with the same heat, cold and temper treatment but the plunge line isn’t as nice so I ain’t showing it here, but otherwise I’m pleased. The thing is scary sharp and I am determined to make knives with this steel. On the warped blade I went down to .02. On the second one I only went down to .040 and had no warping. I clamped the first blade to aluminum stock during cold treatment and laid it flat in the slurry. On the second blade I placed it spine down and did not clamp. So how low can you go on the bevels? Did the first blade warp because of the clamping and possible uneven cooling or was it the thinness of the edge? If I could get it down to .02 before HT I would be super stoked but I don’t want to ruin another blade. A 2x72 grinder is on my list but I’m married and want to keep my nutsack attached to my body.
