It would vastly depend far more on the heat treatment and the processing of the knife by the manufacturer than the name of the steel on the blade.What is the difference and which one is better for a santoku knife? Will it hold on 12 degree per side for cutting vegetable's and boneless meet?
Does any of those steels achieve better results with the best heat treatment for that steel?It would vastly depend far more on the heat treatment and the processing
If you care that much about the details buy a custom knife.Does any of those steels achieve better results with the best heat treatment for that steel?
I heard a lot of good words about AEB-L but it looks like there are more offers for 14C28N and it is suppose to be very comparable.
How do I know if the manufacturer did the best treatment to the knife I am going to buy?
I care about only one detail - the edge! I was thinking about making it myself buying steel from Steel Barrons in NJ but I found that heat treatment at Peter's Heat Treat will cost me $70-100 so I decided to buy a ready made knife.If you care that much about the details buy a custom knife.
Well there's a hidden cost of things.I care about only one detail - the edge! I was thinking about making it myself buying steel from Steel Barrons in NJ but I found that heat treatment at Peter's Heat Treat will cost me $70-100 so I decided to buy a ready made knife.
Benjamin, it comes in sheet format so it's not all on thin coils that get annealed in coil form in a giant furnace, some is left as thicker, wider sheet and is cut and sold in sheet and flat bar.AEB-L and 14C28N are going to be functionally equivalent to one another in most real world use conditions and while there are differences on paper it's something few end users are going to be able to perceive readily, since other differences are going to have much more impact. The main reason AEB-L isn't used more, to my understanding, is that unless something has changed recently, it's only sold in roll format, meaning it has a "memory" of being coiled, and has the tendency to warp in heat treatment if not fully normalized.
Things must have changed in the past handful of years, as that was the explanation I'd seen given previously. At the same time, there was a point not long ago that A8Mod was only available in 1/2" thick or thicker and it's now available in knife-sized stock, if a bit spendy.Benjamin, it comes in sheet format so it's not all on thin coils that get annealed in coil form in a giant furnace, some is left as thicker, wider sheet and is cut and sold in sheet and flat bar.
I worked with Spyderco on the heat treatment for the AEB-L mule team fixed blade knife, we didn't see any significant problems with warping during processing.
Normalizing is strictly for lower hardenability carbon steels which require rapid quenching in water/oil to harden and don't harden in air.
Normalizing is usually used after forging to bring the steel back to a more "normal" state to then further anneal and harden from.
When we normalize carbon steel, we still have soft ferrite and carbides however in air hardening steels like AEB-L would basically harden with attempting to normalize them like carbon steel due to the higher hardenability thanks to the chromium.
Should also be noted the alloy carbides are very stable at higher temperatures and they don't readily dissolve like the cementite in carbon steels, in fact, some air hardening steels having stable alloy carbides even in melted liquid steel.
Figure 1. Thermocalc showing phases at equilibrium for RWL-34. The "Acm" like we see on carbon steel does not exist since we have two phase austenite (FCC_A1) all the way to liquid, meaning there is no single phase austenite to normalize to due to stable, primary alloy carbides shown as M7C3 ( K2 chromium carbide)
So with air hardening steels heated past Ac1, we would bring things back to soft ferrite and carbides by using a temper anneal or a transformation anneal. No normalizing step is needed and it may be detrimental if used.
However, the as supplied condition should be fine.
If anything is done it would be a stress relieve which is under A1.
I'm not sure why it's not used more in production knives, but it is used significantly in the custom knife world. When I talked to Brad at Peter's Heat treatment at Blade Show 2021, he said it was the most heat treated blade steel they run for heat treatment at the blade division.
I speculate many production companies perhaps don't distinguish AEB-L from 420HC which is unfortunate since the characteristics of the material have been known and made famous by both the work of Dr Verhoeven and Roman Landes since at least 2005 and it's very different from 420 HC as we know.
Well, for all the things that change, somethings don't. I think that Rinaldi American boys axe is my favorite axe. Hope all is well.Things must have changed in the past handful of years, as that was the explanation I'd seen given previously. At the same time, there was a point not long ago that A8Mod was only available in 1/2" thick or thicker and it's now available in knife-sized stock, if a bit spendy.
I agree 100% that a custom knife is 1000% better than "a knife". The same as a custom made car is 1000% better than an off a shelf Mercedes S580. However, while it is possible to built such car it costs $5 000 000 and some people do quite well in a Toyota Camry.When you're paying a quality maker for a knife, you're not just paying for the materials, you're also paying for the 100,000 of hours put in to be good at it.
Given your priorities, you should be asking about grinds first, heat treats second, and steels third.I have a different Hobby - I love to eat. It is not that I love to cook, I like the result of cooking. That is why the chef knife is a utility for me, not a toy. However, a dull kitchen knife irritates me. That is why I am looking for a Toyota Camry in kitchen knives: lasts forever, no maintenance, and bring me from the point A to the point B, most likely without excitement or feeling special but also without irritation. That is why I don't care if my knife's handle made of Ash and not olive wood or whatever their handles Custom Knife makers brag about, the blade has scratches and the spine has manufactured defects. But the edge has to be made right to cut beautifully through tomatoes and cucumbers.
Thank you very much for informative reply. May I ask you to tell more about 3 things:Given your priorities, you should be asking about grinds first, heat treats second, and steels third.
I have similar priorities for my kitchen knives, but a really good knife makes it more of a pleasure to cook. Sharpening pleasure also figures in, which is why almost all of my kitchen knives are carbon steel, not stainless.
There is no such thing as a "no maintenance" kitchen knife. You have to sharpen, and after you have sharpened enough times, you have to thin it, to maintain the same performance.
b)grinds first,
c)Sharpening pleasure also figures in, which is why almost all of my kitchen knives are carbon steel, not stainless
Thank you in advanceafter you have sharpened enough times, you have to thin it, to maintain the same performance
