Happy Holidays all. I am thinking of rebuilding my AFCK. This is the model when they first started tapping the screws all the way through. The blade is little long in the tooth but not bad really. Just starting to get a little bit of recurve to it towards the ricasso area. I will say this it is without a doubt the sharpest BM I have ever owned bar none. SO I guess I will leave the blade as is. That and they won't send anything to you through the mail. I want to do this rebuild myself with just washers etc. Far as I can tell that is the only thing I think it needs.
The lock up of the liner is starting to hit just past center on the knife and the pivot adjustment is nearly bottomed out. I am assuming that you don't replace the pivot screw or the female stud itself just cause it doesn't get that much wear on it. So I am thinking the washers are probably just worn from opening and closing etc. I would also like to scallop out on the left scale a small area to better disengage the liner lock. Anyone ever do this? Has anyone ever rebuilt there own AFCK? As usual any and help is appreciated. Keep'em sharp
