Affordable Knife Sharpener?
I only own a couple of knives, but would like to keep them sharpened. I did a search and seen recommendations for Wicked Edge, Wicked Edge, etc, but I'm not about to spend $200-$600 just to sharping my $40 EDC knives. Are there any other more realistic alternatives?
Spyderco Sharpmaker is excellent at touching up, but if you want to do reprofiling. I would recommend the KME Sharpener. It's a lot more affordable than Wicked Edge and you'll get the same results.
Depends on what sort of sharpener you're looking for. I sell a sharpening block through the link in my signature below, can do a full range of sharpening and is a good into to freehand sharpening. Also very affordable. Plenty of video and a copy of the user's manual in the sale thread.
Martin
If you want to keep it simple, get the Fallkniven DC 521 benchstone and learn how to freehand on YouTube and practice a ton. It is far and away the single most versatile stone money can buy. I think it is the only stone on th market capable of being versatile enough to be a one stone does it all solution. One side is a 600 grit diamond stone that is a pretty aggressive cutter for 600. I think it cuts a fair amount faster than a DMT fine (600), yet still leaves a comparable finish. The other side is fine black ceramic that leaves a nice polished edge. In fact, it leaves more of a mirror polish than my king 8000 waterstone and identical to Shapton 8000 glass stone. Because it is a diamond/ceramic it does not need flattening and can be used dry. At about 8 inches, it gives a little more real estate to do larger knives than the dmt 6" stones. 600 to 6000 may seem like a big jump but the ceramic makes quick work of refining the scratch pattern from the diamonds. Should be able to find it for under $60 if you shop around a little. If you arent willing to learn how to freehand and/or not planning on re-profiling, the sharpmaker will work well for you as the others have said. Just as with anything, it all comes down to how much time and money your willing to invest.
