Affordable thermocouples/pyrometers?
Hey all, I've been told that I can get decent HT for 1084 or O1 in my coffee can forge with propane if I use a pyrometer to measure temps and adjust gas flow accordingly. Apparently it can be accurate to within 5°F.
Pyrometers and the like seem to be kind of pricey for my shoestring budget, so I was skepical when I found this one http://www.amazon.com/AGPtek-Channel-Digital-Thermometer-Thermocouple/dp/B0084JQL1Q/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=KRTCXSJD14OA&coliid=I1EBRMT8DMK5TL#productDetails
Does anybody think this would work for my needs? Would I have to buy any extra equipment?
Thanks a ton,
J.P.
I don't have any thermocouple experience myself, but this one interested me because of the price, and I'm looking for one myself, so I was reading about it. As it is it looks like it'll work fine, but you'll need to order different probes from somewhere else, the ones that come with it won't work above approx. 400~ F.
The reviews didn't seem to bad.
thermocouples are made from the junction of two dissimilar wires. K type thermocouples are good to about 2400degrees F. They are comprised of two wires; one is chromel and the other is alumel. When the two wires are joined mechanically the produce a voltage at the junction which is dependent on temperature. Thermocouples are usually made by welding the two wires together at one point, the end.
Thermocouple extension wires are also made from two wires; chromel and alumel. This is done to eliminate forming two new thermocouple junctions at the points where the thermocouple wires connect to the extension wires. The extension wires may not be of the same purity as the wires used to make thermocouples but can be used for such at some loss of accuracy (a few degrees plus or minus at 2000degrees probably won't matter in heat treating) so take the cheaper extension wire, twist the ends together and weld a small bead on the end. Use an oxy acetylene torch, or a carbon arch torch. Then un twist the wires so just the weld joins the and you have a thermocouple. It might be slightly off in temperature but can be calibrated against a known factory made thermocouple and adjust accordingly. Repeatability is what you need and they work just fine for this.
Jim Arbuckle
ABS JS
Jim, this sounds like good advice, but I think I need more explanation to understand fully (excuse my ignorance). Are you saying that I'll be able to use the probes that come with the thermocouple with a little modification?
Tech talk aside, here is what you need. I've used this super cheap setup testing my forges. The cheap Chinese thermocouples may not be the most accurate, but unless you get a defective one they are certainly close enough for what we need. Something with a 50mm/2" lead could easily be permanently mounted in most forges.
On eBay, look for 1250° C Type K thermocouple with at least 1 meter long leads.
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=k+thermocouple+1m+1250&rt=nc&LH_PrefLoc=0
On eBay, look for a multimeter that has a temperature setting
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=multimeter+temp&_sop=15
I have been reading this thread, and have some thoughts and info that may help when making choices about forges and temperature measurement.
If you drive a Yugo, it won't matter how fancy the Michelin tires are, it still won't be a high performance car.
In the same way, if you have a soup can forge, you won't get a highly accurate HT, or much of anything quality wise. Using a pyrometer will help a bit, but it won't compensate for the extreme temperature variations in such a forge.
If I could recommend any single expenditure as being money well spent, I think it would be making a proper forge. This might cost all or $100 at the top end, and as low as $30 with some scrounging skills, but will save you hours of work wasted on a bad HT or a poorly forged blade. An 6-8" diameter by 12-16" long piece of pipe and some refractory supplies from High temp Tools and Refractory will make a very serviceable forge. A bean can lined with Plaster of Paris is just not going to work nearly as well. Propane burners can be made from scrap piping and a few things from the local hardware store for almost nothing,...... using a $30-50 propane plumbers torch is a waste of time as well as a waste of money. Add a cheap ebay PID and TC, and you can tell what range the forge is running at. NOTE - The TC is not necessarily telling you how hot the blade steel is!!!, that is why they are almost useless in a small "can" forge with minimal refractory and insulation. In a regular size forge, after the forge has run for a while and soaked the refractory to even out the chamber heat, the TC can be a fair indicator of the blade temp.
For a little more money later on, you can make the forge run automatically with temperature control by making it a blown forge with a two-stage controller.
The sale price of one hunting/fishing knife can pay for the whole forge, and the sale of a second one can pay for the PID controlled burner setup.
For checking a blade's temperature in a forge with poor heat control and limited space ( or any forge/kiln), probably the best and cheapest method is to use Tempil-Stix. You don't need a big set of them when using these type forges. A set of 1400F, 1450F and 1500F would do just fine. Mark the blade in several areas to determine how even the heating is going.
http://www.tempil.com/products/tempstik-test-kits/
Another method is the pyramids and cones called Segar cones. They slump down when they reach their rated temperature. Just like the crayons, a set of three temps would help you a lot.
Getting a low cost PID and TC from ebay is good for a low budget starter system, but a better grade PID controller unit, a 10 gauge TC with ceramic spacers, and a 3/4" ceramic sheath from Auberins or another quality supplier is money spent once. If you know your stuff about PDs and TCs, you can find what you need on ebay, but sadly, most people look at the price and stop there. This is one of those places where cheaper usually does mean less quality. The types of TCs and stuff you need is in the Sticky on PID Control and forges. All TCs are not the same, and there is more to it than just hooking stuff up with wires.
The info is elsewhere, but the basics are;
A TC needs shielding from the erosive atmosphere in the forge. The cheap stainless/monel clad TCs will hold up for a while, but will burn up eventually. They also usually have fairly thin bi-metal wires. What you want is a 10 gauge (1/8" thick leads) type K thermocouple with 12" long leads. It should come with ceramic spacer beads to keep the leads apart. You then need a 3/4" ceramic TC shielding tube. 8-9" is plenty long here. You will need a TC terminal block to attach to the end of the TC, and several feet of type K connector wire ( attached to the TC connector block, and at the PID). The wire and the TC are polarized, so make sure you hook + to + and - to -.
The PID can be of several types, but make sure it runs on the voltages you use, and takes type K input. In a PID, you usually get what you pay for. Spending $15-20 more for one from a know source is probably a good idea for the novice.
Thanks for the advice bladsmth, maybe you can help with some questions.
I'll do some scrounging around and look for pipe to use for a forge and burner, as well as better refractory. Are there plans I can look at to help the build along?
Also, I have no experience with electronics. For now I'll probably go with the cheaper PID/TC, but how complicated is it to set up? How many calculations will I need to make to figure out voltages, resistance and the like?
Thanks again,
J.P.
Tons of plans. Many in the stickys at the top of the Shop Talk page.....you have read ALL of the stickys, haven't you :)
hightemptools.com has a forge gallery with lots of pictures, FAQs, supplies, Forge kits, Burners or Burner kits, Propane regulators and hoses,....everything you will need.
I need to catch up on my reading :rolleyes:
Any other advice that isn't in the stickies for someone on a minimal budget?
Thanks again for the help
One place you can economize is on the forge shell. While a piece of 6-8" pipe is great, a used propane/helium/freon tank or other cylindrical object can be re-purposed into a forge.
Another thing that can work for young folks this time of year is to carefully research the materials needed to make the forge. Make a list of items from High Temp Tools and Refractory. Print out the list with the prices ( probably about $70-100 total) and give it to your folks/Grandma/etc. and tell them that is all you want for Christmas this year.
If you make a list, post it here and I'll see if you covered all the things you will need.
So just a basic, tentative list of what I'll need:
Forge:
-shell
-refractory
-burner components
Temp Control:
-thermocouple probe/ceramic jacket(?)
-PID unit
What am I missing?
Also, will I need to hook something up to control the burner with the PID or can I adjust manually?
Koa Wool? If you are not building a brick forge, I think folks generally fill it with Koa Wool.
That looks good.
The refractory lining is a 1-2" layer of kao-wool, 1/4-3/8" satanite, and a coating of ITC100. Spraying/painting rigidizer over the wool is a good idea, but not absolutely needed to build a forge. It helps keep the wool from flattening too much on the bottom side under the weight of the satanite.
No, you don't need a control unit. A simple 1/4" needle valve ( which comes with the regulator and hose from HTT&R, IIRC) is all you need. You can add the control unit later on with no modifications. It will just replace the needle valve.
One good extra is a set of Quick Disconnect gas fittings (HTT has them) for the hose. It makes it just as easy to un-couple the gas hose from the forge as it is to un-couple an air tool from the air hose. It also allows the gas hose to be hooked up to any other LP gas appliance is seconds.
I know I sound like a salesman for HTT, but I really haven't found any other source with as much forge and related parts and materials anywhere. They are very knifemaker friendly...because they are knifemakers.
They carry insulboard, many types and sizes of kao-wool, forge building supplies, and all sorts of burner items.....plus a lot more. If you have never looked through their site, you should.
Awesome, I'm going to do a little more research before I get any more invested into the project.
Also my sister is learning glassblowing up in VT and the studio owner has a blacksmith shop. He said whenever I'm up to visit he'd give me some proper refractory to use. I can get my hands on an old fire extinguisher to use as the forge shell, so this budget thing is working out pretty well :thumbup:
Without trying to give a tutorial on basic thermocouples let me make a few statements then refer you to the Omega website. They have a wealth of information on temperature measurement and what is needed to do it.
Different type thermocouples have different temperature ranges.
Some temperature controllers can be set up to use a variety of thermocouple types and some controllers are dedicated to one type of thermocouple. Check before you buy to make sure the controller can be used with a Type K thermocouple. And before anyone jumps in and says there are thermocouples that withstand higher temperatures than type K; yes there are, they are mostly platinum based and really expensive.
A thermocouple made with thermocouple extension wire is less accurate than factory made thermocouples and is less expensive.
Here is the link
http://www.omega.com/temperature/pdf/thermocouple.pdf
Enjoy
Jim A.
