Aftermarker belts for KO Work Sharp Grinder Attachment
Does any one have any links to suppliers of belts that will work on the KO Blade Grinder Attachment. I'm using Econaway belts at the moment and they are great but they don't have the really fine belts I'm looking for at the moment.
I've done a search on the forum and haven't had any luck with this.
What level do you want? I think WorkSharp has about the finest belts I could find.
Here's a thread about aftermarket belts, and it has links to some other threads. (Most of the companies mentioned will have belts for the BGA).
Thanks for the link, as for factory belts, I have no issue with them except the cost. The one's I get from econaway are as good or better and much less expensive.
No problem. (BTW, in this case when I said "finest belts" I was referring to grit level, since you said you were looking for 'really fine' belts... not quality). :)
The Econaway's go up to 2000 grit. How fine were you looking for? There are also leather strop belts, maybe you could load one up with whatever compound you want and that could act as a very fine grit belt for you, I dunno.
