Aftermath Clip?
Hello All:
Just a quick and easy question for you Camillus-savvy folks out there... I have an Aftermath which I would like to occassionally carry. My qustion is - are there more than on clip which would work on this knife? On mine the clip attaches by the pivot, and goes straight down. I thought I saw a clip that goes up, bends 180 degrees, and then goes down, obviously allowing a deeper carry in the pocket. Am I imagining this, was it on a different Camillus knife, or is it available? If it is, how do I get one?? Sorry to be so stupid on this, but I'm just getting into Camilli...
Thanks in advance,
Greg :confused:
go to www.knifekits.com
click hardware, then specialty parts, then foldover clips near the bottom of the page.
These are stainless steel, and better (less likely to get bent) than the old Ti foldovers DDR used to use.
Guys,
Understand, when we designed the heat/dominator/aftermath......we looked at that same clip. We considered using it, but we ran into potential problems. If you mount the deep pocket clip on the knife, the Flipper will sometimes[most of the time] ride BELOW the hem of you pants pocket......which can catch the flipper as you draw the knife and activate the assisted opener before you want it to........which can be exciting in the least, and bloody in the worst :rolleyes:
Mine and CAMILLUS' recommendation is to stay away from the slightly deeper pocket clip for the assisted openers mentioned above.
