Aging 1095 steel
I make "period" (1700 - 1800)knives out of 1095. I have used bleach to age the blade, but don't the finish. Are there any other method that I could use and if so what are they? Also to what grit should I take the blade to, I have been going to 600?
Thanks,
Union Creek, I too make early style knives, I have used all the following with success. Depending on what look you are going for try hydrogen peroxide or mayonaise/mustard or plain old vinegar, wipe on, leave overnite, clean up the next day. For pitting effect use some muratic acid (carefully), then age to your liking. Hope this helps, Bearclaw
Have you tried dilute ferric chlorid? This puts a beautiful grey finish on tool steels.
Also try strong vineager (15+% ) saturated with table salt. Place the blade in this solution and warm it gently on the stove. Watch those bubbles! You might want to wear a fumes mask and I promise your wife will love you for the wonderful smell this process brings to your whole house!
Totally new website!
www.wilkins-knives.com
Ah Sir, This is something I have been doing a lot with lately. Here is how I do it. Buy common hardware store Muriatic acid(HCl 20%), throw in a small handfull of forge scale(iron oxide) and some water to dilute. it will turn black greenish(forms iron chloride?) Put it in a plastic pan of some sort(big enough for your work) that you can cover with a piece of glass or plastic. make some sort of wooden rack to elevate work above level of liquid. Clean work well, degrease. Place on rack over acid, cover, go home. next day it will be covered with spotty rust. using an old paintbrush(natural bristle) scrub acid mix onto surface wiping off to leave a thin film. place back into pan on rack, cover and go home. the next time you look at it it will be covered with an EVEN brown layer of superficial rust. Scrub off with FINE steel wool and oil. Ta Dah! I have gotten very good results doing this, a nice even black-ish patina. If you skip the first step of letting the work start from just acid fumes, it is very hard to get it even. have no idea why. discovered this by empirical trial and error. mostly error. You CAN just slop acid on and let it sit in open air, but the results are very unpredictable.
Thanks Guys,
I have been flying by the seat of my pants since starting to build knives. That is until I found this site. I ordered Allen Blade's video on flat grinding also, Allen only lives 60 miles from me. Hopefully we can get together some day and I can get some more tips from him.
