Air/electric tools?
I had just got an email from Wayne saying he had just straightend out an electricle cord problem he has been having. Got me thinking that one thing I'll be replacing in time will be a compressor. I never really did use it much for knife making but it got me thinking about air tools. When air tools are not being used there normally not connected to the hose and if they are its just one hose. I never have used any air tools but sure see alot of them advertized. Any pro/cons about them?
I own both corded and air tools. Big plus for air tools is that they are normally smaller and much lighter than the tools that require a motor. Minus is that you need a fairly large air compressor. When I am using my air sander, I have to stop periodically to let my compressor catch up. It is a 5hp 25gallon Craftsman, the biggest I could find that would run on 110v. And they are noisy so you want them in another room (soundproofed) if possible. Air tools themselves are somewhat quiet depending on which tool and which brand. Of course that is all relative since I am partially deaf anyway.
Electrical tools generally cost a good bit more, and their life can be short if you use them hard.Brushes burn out, armatures short out from metal filings etc . Air tools can be had cheaper usually, and seem to run forever with proper care (generally just a shot of oil now and then). No brushes, magnets or any of that stuff. You can also plumb your shop to have air hook ups just like electric, bout like running conduit anyhow it just has to be air tight and hold 150 psi or so.
Trouble with air tools is you have to have quite a compressor (something in the neighborhood of 10 cfm at 90 psi) to run anything with them. My dad has a 5 hp 25 or 30 gallon compressor (might go about 5 cfm at 90 psi) and its pretty much a joke to try and do any serious work with it on a rotary type tool (sander, grinder, die grinder, cut off wheel etc. ) You get good speed out of it for a few seconds and then you're waiting on pressure to build up again.
And because you need a huge compressor to run them, you don't really get much use out of an air tool outside the shop. Its not too hard to drag out extension cords, or even a generator, but a 500lb air compressor is a different story :D
So if you can get a big enough compressor, and plan on mainly using them in the shop, I'd go with the air tools. If you plan on using them outside the shop much at all, then I'd go with electric (except I would stick with air powered nail guns, impact wrenches, and other stuff like that where you don't need such a high volume to run them)
Ray, the above posts have pretty much hit the nail on the head. You'll trade speed for torque when goin' with air.
I find that the smaller tools, 1/4" die grinders and such serve me well both in the knife shop and the body shop.
When you're lookin' for a new compresor, DeWalt's commercial grade machine is a winner. They bought out the Emglo Company from Johnstown Pa. , a helluva machine!!
Hope you're makin' some headway out there. bruce
Use air tools a lot here in the shop. Used to port heads for drag cars. Tractor supply seem to beat Sears, Lows, Home Depot, in price. The Ingersol compressor that they carry, ll cfm, at 90psi does a great job.. The sears job is over priced, under powered, and the dinn that it makes will drive you crazzy. Just Look at me now!!!
