My recipe for A2 closely follows the Crucible data sheet and goes like this : first I enclose my blade in a foil envelope. Then its into a cold kiln. Ramp full to 1200*F , equalize (5min) Ramp full to 1400*F , equalize (5min) Ramp full to 1775* F (austinitizing temp) Soak 40min.
Out of the kiln and directly in between 2 aluminum pieces of barstock that I use specifically for plate quenching (I should add that before I put my envelope in my kiln, I get a vice grip welders clamp set to a snug snap for the width of the 2 alum bars + my enveloped blade) Like I was saying, I take my envelope out of my kiln and clamp it between my alum plates. Immediately following that I snip the blade end of my envelope off with tin snips and blow air into the envelope with a vortec cold air gun. All of this is done on top of my biggest anvil. I have a clamp set-up for the cold air gun so that I can direct the air flow into the envelope hands free. As that is happening I snip the back of the envelope off so that the air free flows through. I have some nice thick alum plates and in combination with the vortec they are very efficient at removing the heat from my blades.
Temper @ ~ 475* for 2 hrs x 2 for a final HRC of ~ 59-60
My as quenched hardness is always right in the ball park (@~64HRC) with the data sheet.
Crucible Data Sheet defines A2 quench as "air or positive pressure quench (2 bar minimum) to below 150*F (65*C)"
All of this being said, I've seen other knifemakers get good results by simply holding the envelope in front of a fan or regular type air gun.
When I was working in the shop I saw our heat treat guys pull die punchs out of the kiln and place them on an expanded metal table to cool all on their own. No forced air whatsoever. A couple of temper cycles and then on to punching out tens of thousands of parts.
I try to cool my air quench blades as fast as possible, using both quench plates and forced, cold air. So far I've had very good results .
Everyone seems to do it a little bit different though.
:thumbup:
