Utilizing the traditional Chad Carroll http://www.carrollknives.com folder design, we came up with a corrosion resistant, firm grip, strong-yet lightweight, folding knife that cuts like a razor and stays sharp forever. It took 11 months from the time we started the collaboration to come up with this result.
All components of the knife were handmade by Chad himself.
Folder steel: Forged from 1 inch round 52100, Black-T coated by Walter Birdsong, cryotreated by Jeb Burnett from Deep Freeze Cryo.
Scales: Black G10 hand checkered 30LPI
Bolsters/Backing: cut from flat bar of titanium, backing hand checkered 30LPI
Liners: .050 titanium sheet then drilled and tapped for 2-56 threads.
The bolsters and scales were dovetailed, and screwed to the ti liners.
Screws: "14 titanium screws per knife all but the pivot screws were from .125 titanium round bar. The screws were turned to .08-.083 for the thread section and then threaded with a free chuck and a button die in the tail
stock. Then I cut them off with a little extra material on the head. That section took about 1 hour to make 8-10 screw bodies. The heads were ground to 220 grit for finished size/ shape and slotted freehand with a thin abrasive wheel." (quote from Chad himself)
Clips: made from .040 sheet of titanium
Thumb stud: purchased, titanium, then ground/hand checkered 30LPI
Pivot pins: turned and polished, drilled and tapped from 3/16 titanium rd rod. They were turned specific to each individual blade to make the fit up tighter. There is a .012 nylatron washer on each side of the blade.
