ak47 pics w/ ghetto kydex
mic specs taken 2" forward from the end of the choil (where the edge begins)
1/16" - .051
1/8" - .074
1/4" - .091
3/8" - .126
1/2" - .157
5/8" - .176
3/4" - .197
7/8" - .202
1" --- .202
spine- .202
this next set is from the tip going along the spine towards the handle
1/16" - .065
1/8" - .079
1/4" - .100
3/8" - .131
1/2" - .156
5/8" - .180
3/4" - .191
7/8" - .200
1" --- .201
wich is odd. visually against a ruler it looks like 3/16 (3/16 = .187, 1/4" = .025, but when i mic it out its .202. when i hold the mic up to the ruler (at.202), it is quite visibly more then 3/16", so i guess its just a trick of the eye combined with the powder coat.
overal handle thickness =.927, making each slab .362 (making the slabs just under 3/8" thick each)
very solid blade. there was a comment made that it set a new standard of sharpness, wich i would contend, at least as far as knives are concerned. i could not comment on wether it is sharp in comparison to other wakasashi's. were it a knife, the edge itself wouldbe at a fairly obtuse angle, and the tip would be quite obtuse (as most of the larger busse's tend to come sharpness wise from my experience). on this blade, that may be required due to the excessive stress put on the edge by the extra length, again i cannot comment without experience in testing the difference that edge angles and geometry make in a wakasashi/katana.
the sheath is something i threw together the night before we left for reletives houses. i started at midnight, and we left at 4am, so it was a rush job meant basically only to wrap the edge for transport. ideally i'd rather have rivets at the junction points instead of bolts and nuts, or at least chicago bolts. i'd also rather the rivets be spaced in accordance to a large techlocks spacing (but i dont have one to measure them out with) as apposed to just randomly hand drilled.
not to hard of a sheath to make... kind of anoying to rivet though.
this wakasashi makes an intersting thrower/spear... not ideal, but certainly interesting.
lots and lots and lots of rivets...
seth,
nice job on the sheath. For Gheto, the sheath looks good.
that is next to a .220" SJLE saber grind 3rd gen handle
you can see the ruffels, wich run parallel to the spine (they dont curve with the edge near the tip)
there is a lot of potential for customs made from this blade by cutting down the length of the handle and blade.
That sheath doesn't look all that bad man. You might have been able to get away with fewer rivets if you spaced them out a little farther. It looks like you got that thing good and tight though.
do you know how far apart the holes are for a large techlock? (the part that lets you bolt it to the sheath)
just a rough estimate, iether from the center of one hole to the center of the next or even how far apart the two edges of the holes are.
Hey, great job on the sheath! More than just a transporter I would say:thumbup:
Also, thanks for posting the pics! i ahve been looking all over the postings to find pics of this sword. I ordered a tan one with the crinkle finish last night, and was wondering what the finish was like. Your close-up pictures answered that one for me.
once i get measurements for the techlock distance, i'll see about making a few more... i can get a sheath per kydex sheat, wich isnt half bad.
(but good this time (straight edges and the likes))
Nice Job on the sheath!!! Awesome pics! Better make sure your nieghbor isn't on the other side of the fence, There's a LOT of blade there;)
Damn Seth... those are some really good pictures bro! I had no idea the handle slabs were so thick. Nice job on the sheath man, wouldn't call it ghetto at all.
Congrats! Makes me want one even more now.
SethMurdoc said:
... visually against a ruler it looks like 3/16 (3/16 = .187, 1/4" = .25, but when i mic it out its .202. when i hold the mic up to the ruler (at.202), it is quite visibly more then 3/16", so i guess its just a trick of the eye combined with the powder coat ...
Measurements with a ruler can be tricky depending on how square or rounded the edges are, how even the item being measured is, and I would guess the coating makes it more difficult to get a precise measurement with a ruler.
That's a nice looking AK - I like the black crinkle/black micarta combination; your sheath looks good too! :cool: Thank you for the info and great pictures!
Gene
I am really interested to see if Jerry makes 6" blade version with the handle cut down to make it around 11"-12" overall. I think that would kick arse :thumbup: .
