Cliff Stamp
BANNED
- Oct 5, 1998
This is basically a Spyderco Rescue with a H1 blade, a stainless steel which is actually stainless meaning it doesn't simply resist corrosion it is immune to it even in extreme conditions, extended salt water or food acid soaks do nothing to the blade.
What you get is a very large grip ergonomically contoured, a large opening hole and a large blade with a very aggressive serration pattern which is still fluid enough to cut a piece of hemp rope with the same amount of force as as a properly sharpened Opinel.
The back lock is solid and secure, no issues even after extended use. The only real concern is that white knucking type releases can happen in some grips if the lock release is accidently compressed so work with it to determine what grip positions are so sensitive.
In terms of general utility this is a fairly focused pattern with no point and a fully serrated edge and thus does not lend itself well to a lot of tasks such as various types of food work, wood carving, or precision point cutting. The blade does however offer a very aggressive slicing profile with a very high level of edge retention, especially attractive in abrasive and/or dirty materials.
I gave it to my brother who carried it for several months while working in construction, it was the only folder I have seen him carry which stayed sharp and would not fail to soon cut anything. Even with high end steels, cutting dirty material blunts them fast, however the Salt kept going and would only be sharpened very infrequently, essentially ever couple of weeks to a month when I inspected it.
The serrations also proved to be fairly durable, some of them rolled a little but as noted they frequently cut very hard and/or used material, and there were no large problems with breaks and the knife is still doing strong and has developed on issues with the lock. The large grip gets frequent praise for the ability to work with gloves and the ease of opening of the hole for similar reasons.
I was never one to look for serrations and for a pure daily carry EDC I would generally prefer a straight edge, however the ability of this knife to keep functioning in a very rough enviroment and the added strength of the tip might make it attractive outside of its promoted role as a "rescue" style knife, which it would also do quite well.
Ref :
http://www.physics.mun.ca/~sstamp/knives/alantic_salt.html
-Cliff
Ref :
-Cliff
