- Feb 24, 2000
Maybe 20 years ago I bought a lot of W-2 steel from Aldo. I could not get it to harden, so I set it aside and pretty much forgot about it. The other day I was looking At Aldo's site and saw his Heat Treating recipe for W-2 steel.
I cut three coupons off three W-2 bars I had. I used my Paragon oven and heated them to 1650F for 12 minutes, took them out and let them cool. Then I put them back in at 1500F for 122 minutes and took out and let cool. Finally I put them in at 1,350F for 12 minutes took out and let cool to room temperature.
I hardened by heating to 1475 F for 10 minutes and quenched in Park's 50.
After they had cooled down I tried a file test. The file did not skate off the steel. The file cut into the steel. I put one of the pieces in a vice and beat on it with a large hammer. After a lot of hits, The steel bent, then broke. The grain was very fine. Then I ground the de-carb off the last two pieces and tested with my Rockwell tester. One piece tested 49RC and another piece tested 51RC.
Using Aldo's recipe the W-2 did get harder, but not hard enough. That was disappointing.
This morning I was going to heat treat another piece of steel and decided to quench the W-2 in water. I heated two pieces of W-2 to 1475F for ten minutes and quenched in water. I did not do any normalization cycles with this steel. When the steel cooled down, a file skated across the steel. On the Rockwell hardness the steel was 63Rc. I put a piece in a vice and tapped with a hammer and it broke. The grain looked as fine as the steel I had cycled.
Back in 1991 I took an ABS Damascus class with ABS Master Smith Charles Ochs. He used water to quench all his blades. I also used water for awhile but every so often I would get a blade that cracked so I started using oil and then when I found out about Parks 50 I started using that.
I hope this information will help someone, and if any of you have experience hardening Aldo's W-2 steel I hope you will share your experience.
