all magnesium the same
So my question is simple- Is the magnesium that is in a fire starter the same that is in a magnesium anode rod or are there different grades or types of magnesium?
There's different grades and alloys - but the Anode rod should still be burnable
I have an old dead water heater I am starting to disassemble, just to see if theres any anode left (and if there is I will be trying to burn it !)
I have had mag bars from China that do not work well. They do NOT scrape as easy and they do NOT light as easy. I got slammed from some folks here for saying all the China ones were junk. Apparently they are not all bad. Bottom line is test whatever you get.
I would recommend Doan's if you want a block mag bar as it is made in the USA and works great. I think the Coghlans are made in the USA now too.
I carry Sparky from Wisemen. Same thing at Survival Resources without the pouch. They both have good Magnesium.
http://www.wisementrading.com/firestarters/magnesium.htm
http://www.bepreparedtosurvive.com/
This sounds familiar. I'm not sure who but I'm 7/10 confident that member here “upnorth” bought a couple of anodes specifically for that purpose and they worked. Don't go live on my say so here though 'till we can get that verified.
It is him.
"The grey chunks are a cut up Magnesium anode used for water heaters, found in any plumbing supply outlet" - upnorth 07-10-2013, 02:09 PM
Thanks for the responses guys. I've been on vacation since I posted so this is the first chance I've had to check back. The reason I asked was because I work in a home improvement store and was walking past the plumbing desk the and noticed there was a special order "Magnesium Anode Rod" that had been returned. I started talking to the plumbing manager just to verify that it was magnesium and sure enough it was. He only wanted $10 bucks for it.
The water heater Anode Rod that I used was bought from a local plumbing supply facility and was cut up with a hack saw. The material is easy to light with plain Jane ferro rods. It is also relatively easy to scrape off with the Speedy Sharp tool. I ended up with far more material than I will ever need. But it is handy to make little bundles and leave them in various back packs, a glove box etc.
