oge14
- Jun 14, 2007
here she is all filleted and ready to go:thumbup:
some of the pic's i took will be in a "how to" thread soon i hope. there were a lot of pic's taken for this one, almost 80 i think. only about 60 or so are worth posting.
anybody want to see a few more pic's? ok you talked me into it.
if the hard use of knive's or blood make you pale please be warned!
ok first you have to make a starter cut.
then work your way around any fin's(handle's) to save a lot of pulling and yanking later. followed by a downward cut.
after reaching the bottom of the fillet, use the rib's(bracing as leverage to start the horizontal cut along the bottom of the fillet.
as you work your way through, keep using the rib's as leverage. or you may have to chop in place's also.
reaching the opposite edge, you need to make a vertical cut. start this by either chopping or using the rib's. as in the second pic, sometime the cut goes astray.
make a better hole and continue up the fillet.
now we come to a tricky cut, something in the way. you should try and work around the obstacle first.
if that dosen't work, remove the obstacle. then take a cool pic with it.
continue the cut all the way across.
then remove the fillet.
