- Feb 27, 2013
Just recently I purchased a CPM S30V PM2 to replace a PM2 that I sold off awhile ago. I assumed the dreaded issue with the red Loctite was a thing of the past as I have had no hardware removal problems for the last year or more.
Well... it is said that man is not consistent but in his capacity to assume and be wrong. I was unable to remove one of the pivot screws. Nothing would budge it. I was replacing the scales so I was able to get purchase access for a pair of ViceGrips by cutting the scales away. Even then I had to apply heat to get the screw removed with the ViceGrips. If I was a conspiracy theorist I'd accuse the factory of playing games with random knives for nothing more than a chuckle.
I've had to request replacement hardware from Spyderco on too many occasions that I have become a thorn. So... I got serious with attempting to source replacement screws. That proved more difficult than anticipated. An identical direct replacement for the Spyderco hardware is NOT available on the retail market as far as my investigation results go.
I decided to go at the problem a different way and not try for a screw of identical appearance. So far I have been able to source some 6-32 X 1/8" button head socket cap screws for the pivot. I also acquired some 4-40 X 1/8" button head socket cap screws for the frame.
It's now just a matter of aesthetics... as the button head cap screws do work as replacement hardware for the PM2's pivot and the blade stop pin screw locations... BUT the 1/8" thread length I purchased is NOT long enough for the mid-body 4-40 screw. There is not enough thread showing to be able to start the barrel spacer so I will need to order the next longer length which is a 3/16" long screw. Those may require shortening...
I'm liking the button head look so they are a go for my knife. I'll post more when I get the longer screws and eliminate the last two mid-body 4-40 OEM screws.
