Hi Cliff!
Having read your post concerning the laminated steel in the NL series from Fallkniven,..........hmmmmmmmmmmm..........
Does that really means that the new NL series is not as strong as the solid blades in VG-10 are??
I bought the smallest out of this knives, NL4, Frey. It seems to be a very versatile knife, and I like VG-10 really a lot! Thinking that a laminated blade really would add some strength to a knife blade, I'm now a little bit confused,.......
Until now I have no complaints with any of my fallkniven, except some minor disclaims....
What I noticed concerning the NL4 is somehow "strange" : Concerning the sheath: It is made of top quality leather, they thought to many points, i.e. concealing the rivets of the belt loop on the inner side of the sheat with a plastic strip to avoid scratching the blade, but on the other hand, the rivet of the (handle) safety is not covered with anything. Result is a noticeable although minor scratching of the handle. But, frankly spoken, this knife is not considered to be a drawer queen, and years of use will for sure change the appearance by leaving some scars. Nevertheless, we'll see how it holds up over the years.
Concerning the shape of the blade it is nearly similar to the shape of the S1, only one big difference: While the S1 has a saber grind with a convex edge, the NL4 has a flat grind that really starts at the spine and moves into a very nice convex edge. Haven't really tested this knife in "real life", I can imagine that it will outcut the S1 by a wide margin. Concerning the tip there's another big difference to the S1, the tip of the NL4 is not as strong as the S1's, it's really a lot thinner and it is not intended to pry out wood from a tree or log.
The edge is more curved than the S1's, so it provides a lot of belly. I like the handle but I think it needs some treatment for regular use to make it durable, I have applied som leather wax and it seems to come up well.
I have to say clearly that this knife would not be my first choice for a survival intention if I am reduced to only one knife but together with a GB axe it would for sure fit the bill.
But I have to say that a knife should be a knife and its primary task is cutting. Do we need "sharpened prybars"?? And if yes, in how many cases? And in these cases,....wouldn't an axe be the better choice? Let's see the Northern Light series as what they are: Beautyful knifes made of very good materials in an ancient nordic tradition with nearly custom grade.
any comments welcome,
greetings,
Gerry
