As you might know, I am currently striving to design a bali that can be a user and not depriciate.
First off, latches are the devil and they must go. A latch damages, at the very least, the other handle as well as the latch itself.
So that leaves only one area of friction, the area where the handles, pins, and blade meet. The handles scratch the tang and ricasso through regular use.
One possible solution is washers. Washers between the handles and the blade cause enough space so that the blade doesn't come into contact with the handles.
However, washers can cause the handles to loosen up quite a bit. I know my BM68 has gotten quite loose in just a few weeks. On knives like the 68 the pins are flush with the handles and tightening up the blade isn't an easy thing.
I've heard that most companies use washers simply to reduce the need for hand fitting of parts.
So what else is there? I dunno. Nothing? A scratched blade or a loose blade it seems.
I have an idea... I'm not sure if it will work though...
Say the blade is 3/16". First mill the handle slot at 3/16". Then mill the handle slot slightly larger, all except for the last 1/4" or so. So all the friction happens where the handles are 3/16" and the blade doesn't get touched where the handles are slightly larger.
Man that description sucked, hope the pic helps.
What do you think? Dumb idea?
"...all power is inherent in the people... it is their right and duty to at all times be armed." Thomas Jefferson (1824)
