Altoid Tin Fire Kit.
I have an instructional block on fire-making in Scouting coming up. Nothing too fancy as I'll be dealing with a hundred+ Webelos with the attention span of hummingbirds. Basics will be covered & different fire starting methods & tinder will be shown. I'd like to show them a kit that they could be able to assemble themselves. My idea was to use an Altoid Tin as a container for it. Stuff it with a couple of ways to start a fire & a couple of things to use as tinder. I have a few ideas, but I am looking for more.
So what would you stuff in an Altoid Tin to use as Tinder & a way to start a fire?
For tinder, I have become a recent convert to old fashioned char cloth. It is flat, and a little goes a long way, so you can get a bunch in there and still have plenty of space. As an added bonus, you can use the tin to make more char cloth if you poke a small hole in the lid.
I'd also add a ferro rod blank and a few bits of fat wood, and maybe a mini bic? Another fun option would be a steel striker and a shard of flint.
I keep some jute twine in my flint & steel fire kit to use as tinder.
You can also coat it with wax to keep it water/moisture resistant and burning longer.
So far plan on taking a small Bic lighter, matches, ferro rod, vaseline coated cotton balls, dryer lint, fat lightning, and jute twine. Wanting to keep it fairly simple & use items that a kid can easily get a hold of. Also plan on taking a battery & steel wool, along with Frito corn chips just for the cool factor.
A cool trick I learned from YouTube is this: Take a handful of wooden strike anywhere matches, cut toilet paper in strips as wide as the wooden part of the match is long. Wrap the match stick tightly in the t.p. and dip in melted wax. Now you have a firestarter/tinder all in one. Very compact and keeps the match waterproof til your ready to use it. When you are ready, use your fingernail or knife to scrape some of the wax off the match head and strike it--it will burn as long or longer than a pj soaked cottonball
I use bicycle inner tube to shut my fire kit close. It keeps the tin closed and is also a great fire starter, just be sure not to breath the black fumes.
Hope this helps.
To me, it seems like you already have your bases covered. You could maybe add a fresnal lense/magnifying glass as it is common. Also maybe add char cloth (or make some as a lesson). The char catches easily from a fresnal, and you could fluff up some of the jute for a tinder bundle so that they could blow it into flame.
Another thought - mostly for another cool factor item - is some potassium permanganate & glycerin.
For lack of a better term, I keep "fire pills" in my fire tin. They are simple, yet very effective home made starters, more on these in a second. I also keep some char cloth, and small, shaveable pieces of fatwood,Along with a 3/8" blank from the big firesteel website and a striker.
The "fire pills" consist of a cotton ball, gardening (think small) diameter jute twine and wax. The wax I "borrow" from my wife. ;) it is actually just the un-burned wax from her scented candles that have burned the wick out. How about an "instructable", and the scouts can play along?
1. Source wax, and gradually heat in a glass container, that is lightly boiling, inside of another pot. Hint, the hotter the wax, the thinner the consistency, which allows the wax to permeate more of the cotton ball.
2. Roll cotton balls into short, thin rolls and secure in place with the jute twine. Hint, leave a little length after tying so that you have something to hold on to when submersing in wax.
3. Dip cotton balls and place on wax paper to dry. You can "apply" more than one coat of wax to ensure that your cotton remains impermeable by water.
4. Trim excess jute short and, using tongs, dip the area with the trimmed jute to further reduce the chance that the twine can wick water into the cotton.
5. Place in tin and... Always be prepared!
To use, simply cut in the "fire pill", making sure that you are through the wax and into the cotton, expand the cavity you created, fluff the cotton inside, and apply ignition source. Depending on how well saturated your cotton ball was, I have had these burn, we'll in excess, of 5 minutes! You can strike on a piece of bark, and instert directly under a slightly damp twig bundle, and have a cozy fire in no time, with little prep. Really doesn't take much more time to make than char cloth and is greatly superior IMHO.
Good luck and have fun!
DD
I have one Altoid tin for char cloth making/storage and the other has a ferro rod, mini Bic, striker, fresnal lens and fat wood.
