- May 10, 2015
I think I can open my Paramilitary 2 faster than an automatic. Never understood the demonization of auto knives in general.
Wave is the fastest.
Wave is still faster than an auto in cold conditions. You might fumble to press the auto as much as pull out a waved knife in the cold.
I wouldn't automatically assume that fixed-blades are the fastest to deploy. A lot depends on the sheath and retention method.
Some fixed-blade sheaths have straps with snaps. Some of them have really tight snaps.
And then there's kydex. Some kydex sheaths hold the knife really tight. And if you attempt to draw the knife at an angle, either intentionally or unintentionally, it may not come out.
Some sheaths are rigid, but some hang loose and will move with the knife when you try to draw it. A loose hanging sheath can impede a quick deployment.
Some sheaths are "jump rated". Meaning they are designed not to let go of the knife during a parachute drop. These sheaths require a more concentrated effort to draw the knife.
I carry a fixed-blade every day. At work I use a kydex belt sheath. Away from work I use a rigid leather belt sheath with no retention strap (the body of the sheath is just tight enough to hold the blade firmly, but not so tight that I can't draw the knife fast and easy).
There are several variables involved in the deployment of any knife. The knife, clothing, how the knife is carried, where the knife is carried, the body position of the person when trying to deploy the knife, the ability of the person, etc.
Really? A fixed-blade is ALWAYS faster than a folder? Have you tested every fixed-blade and sheath against every folder? Can you point to any government or military testing where every fixed-blade and sheath were compared to every folder?A fixed blade will always be faster and safer then a folder man. Folders are not immune from the issues you describe and both can hang up on draw but, only the fixed will always be open once you draw it and always stay that way. There is a reason real operators, whether LE or Mil, almost always chose fixed blades.
