Amar Thapa Singh Khukuri
Hello all,
I found some pictures about a model HI used to make before?
What is it so special about ATS kuks?
As what i read, ATS was a hero for the Gurks back then.:thumbup:
Anybody to shed some lights?
Many thanks
Jay
JayGoliath,
Welcome to the HI forum. As to the Amar Singh Thapa, it seems like it is an all purpose tool/weapon khukuri. The little work I did with the new AST that I recently got (chopping a 3" maple limb) shows that it will chop but it doesn't excel at it. Hopefully others will come in and be able to give more information than I can with my limited familiarity.
As to info on Amar Singh Thapa, Yangdu posted some information a little earlier. The post is titled "Wednesday Evening with Amar Singh Thapa Khukuri" with a Last Post date of 9/21/09. That should give you a starting point and I'm sure a Google search will supply you with much more.
Rick
Dear Stickfred,
As Uncle Bill mentioned before, the knowledge base and wholesome warmth of this forum is truly empowering!
In your experiences with many kuks, is Chiruwa Angkhola still the best chopper?
Many thanks.
Jay
First of all, Jay, I want to be clear that I'm still new at this and don't really have a lot of experience with all of the khukuris I've acquired. I have used each one to chop through 3-4" seasoned Norway maple limbs that a neighbor has in his "to burn" pile. I'm not counting the strokes but am trying to get a comparative feel as to how they perform. I haven't done it with the Kobras I have because one is pretty small and the other I have relegated to clearing out weeds. I'm also still learning about technique of both holding the khukuri and how to strike with it. I also interject second hand information, as best as I can remember it, from other forumites input-especially from the archives that I am in the process of going through. With these caveats I will try to address your concerns. I hope that there will be others that will jump in, too, since I know that there are many others on the forum that have more experience and can help round out your information.
Basically, yes, the Ang Kholas are the best choppers. The bigger they are, the better they chop. Also, the bigger they are, the more they weigh. The chiruwas, both the 16.5" and the Super CAK (SCAK), at around 20" I believe, perform as well as their standard handled counterparts. Once again, the chiruwa handle is only a little tougher than the tang through standard handle, it "may" transmit more vibration to your hand and I've experienced grey on my hand after using them due to the contact of the tang to my skin. Some people fervently believe that others such as the M43 and the 18th Century models will chop as well as a comparably sized AK and they are probably right. These forward curved models are slightly different than the shouldered AK as to connecting the "sweet spot" and some adjustment to your swing may be needed to bring it to AK level. The Ganga Ram Special also does a fine job of chopping, and some feel it does a better job of felling than an AK, and I am ready to agree with Yvsa that it strikes truer to where I want it to go than an AK. Speaking of Yvsa, his Yvsa Cherokee Special (YCS) is chopper along the lines of the baby GRS. Personally, my best chopper is a Hanuman AK that I have. Uncle Bill called the Hanuman blade a "full Ang Khola" with its two fullers. If it is nothing but a steady day of chopping ahead I would reach for it and probably bring the baby GRS along for a change up and possible limbing. There are also others that feel that the WWII model will do some a good job of chopping and is an excellent all purpose khukuri. (There is an 18" chiruwa WWII on the Exchange forum that I've been watching and just can't seem to decide about it yet.) As a personal aside, I feel that my 18" Gelbu Special chops almost as well at my 16.5" CAK and due to its lighter weight and blade shape could probably do some other things better.
If you are trying to decide which model will be your first khukuri, then first go for the one that connects with you the most (the one saying "Pick Me") and I'm sure you'll be happy. I'm sure you'll expand from there. But if you have a particular future use for your first khuk, it is best to define that use and ask for input based on that. For instance, if you're going to be chopping and splitting wood at home then a 20" AK or CAK is probably what you are looking for. But if you're looking for a general camping blade then the 3-4 pounds may be a bit heavy for packing or extended carry.
Starting to get a little bleary-eyed here so its about time to sign off for the night. I hope I've been able to be of some help and I'm sure you'll get more from others as they check out the posts. Keep throwing any questions you may have out here 'cause there's a wealth of information and lots of good people willing to share it.
Rick
You're doing fine Rick. :thumbup:
The Archives teach you as much about khukuri as it does life.
The only things i might relate is that everyones experience, even with the same khukuri, can be quite different. What works for others may not work as well for someone else due to the differences in people. That is why we always tell people here that they should "pick the one that calls to you" and "the khukuri usually picks it's owner".
The other thing i would like to add is, if you are looking for a dedicated chopper you are going to want to read the warranty and stick to the ones listed for "field use" so that you are covered in the event of failure. While it seldom happens and these khukuri are overbuilt, it is still a possibility as with any man made product. The others, while built the same, are not warranted for "field use" and should be used with great care and with the knowledge that they are not covered. The warranty can be found in the Library, as well as on the websites main page.
I hadn't forgot about 'em C.S. I confused this thread with another asking about Bonecutters, M43s and CAK and wound up skipping over the Bonecutter in this thread. But that's the good thing about this forum, someone will spot an omission and speak up. The Bonecutter is one model I haven't gotten yet and am keeping an eye out for one. I couldn't help but notice that they have garnered much praise among those that have one.
