- Nov 20, 2014
I carry an axe to work daily. My "office" is a control booth on a debarker situated over top of all the hydraulic pumps and the floor is an average of 125 degrees according to an infrared surface temp meter. Just last week, i had a nasty flap on a log that took a fair bit of sustained power chopping. Bouncy target, inefficient work.. Was slinging a single bit that weighs right at 4lb (my average work axes are 3 to 3.5). It was a pretty hot day, too so the axe was baking in the booth a little more than usual. After defeating the loose chunk of pending disaster, I noticed my wedge had started to walk out. Now, I dont always safety-wedge my axes, and this one was hung without one; but one of my other favorite axes has no safety wedge and has seen some much harder (angry) chopping in the same situations. Its never slipped its wedge. What I'm wondering is, did heating the oil in the handle and wedge cause it to slip its bond? The floor of the booth does have a good bit of hydraulic oil coated wood dust where I put the axe when I'm operating, so maybe it wicked up inside the wedge and added to its issue? Anyone ever run into this before, or does it make sense in any way? I will test the retention again this coming week on that same axe with a reset wedge after it gets warmed up. If it slips again, I think this environmental stress (high ambient heat) on a tool might need considering by some hangers/users.
Also, if I were to put a wood cross wedge(s) in, should I split the long wedge before hand or notch it and split it with the second one? I would think i would need to cut the actual secondary kerf into the handle, but I've not done wood cross wedges before. I would prefer not to, but i will use a metal safety wedge of some sort if I have to.
Thanks.
Thanks.
