abbydaddy
- Oct 14, 2014
I got to participate in the Ambush Alpha passaround, this is my review. It's pasted over from my Blog, the Center Gnome. You can read the review on my blog here http://centergnome.blogspot.com/2015/05/knife-review-ambush-alpha.html but I have pretty much everything here. There are a few in text links, but that is all that you would miss out on by just reading the review here.
The Ambush Alpha with the wooden chrysanthemum I made to demonstrate suitability for cutting curls
Introduction:
This knife review represents an exciting first for me, this is the first time a knife was sent to me for testing and review. I only had this one for a week, so the review is based on a fairly limited time frame, but I think I did a good job of covering the basic uses that this type of knife would be put through.
The Ambush Alpha is a general field knife, often referred to as a bushcraft knife. It's designed for all-around camping and hunting use. It features a beefy overbuilt type of design intended for hard use. The blade is made of 3/16 thick stock, with a full (skeletonized) tang running through the handle. It's a solid feeling knife.
The Ambush Alpha is a new knife from a new knife company, Ambush Knives. As the knife was being launched there was quite a kerfluffle over the similarity between the Alpha and some of the knives produced by SURVIVE! Knives. I don't have any experience with SURVIVE! Knives, so I can't make any direct comparisons myself, and I feel like the design of the knife is similar to a lot of other knives designed for the same purposes, but the SURVIVE! GSO-5.1 does look quite similar and is made of very similar materials (functionally identical) as the tester I was given to review. That said, considering how similar many knives designed for "bushcraft" are, I would not presume to cast stones.
For the purposes of the review, it was asked that potential reviewers have experience with heavy duty survival style knives of comparable design, so that the performance of the Ambush Alpha could be compared to the performance of other knives. In my case the knife that I tested the Alpha against was the Spartan Harsey Difensa. The Difensa is obviously somewhat different, but both are made of 3/16 particle steels with high flat grinds, skeletonized full tangs, and micarta handles. For the purposes of this review I think they are plenty close enough for comparison.
Difensa and Alpha side by side. Sorry for the poor picture quality, I was having some camera trouble that day.
Let's Start With the Specs:
Specifications (From Knives Ship Free website):
Overall Length: 10.5"
Blade Length: 5.125"
Weight: 8.8 ounces
Cutting Edge: 5"
Blade Height: 1.25"
Blade Thickness: .187"
Blade Steel: CPM 3V
Blade Finish: Satin (The Blade Finish on the tester is actually stonewashed)
Heat Treat: Differentially heat treated
Hardness: Edge: 58-60HRC; Tang: 43-45HRC
The Alpha is a fairly substantial knife, though it comes in just a little over a half pound. With the center of gravity sitting right at the front of the handle I found the knife to feel surprisingly neutral in the hand, and lighter than I expected.
The handle of the tester was made of contoured canvas micarta (though the Alpha is available with a number of handle options including G10, antler, and various woods). Micarta, as I have discussed in other reviews, is a handle material I fully approve of. I find that micarta, when given a rough finish as it was on this knife, feels almost soft in the hand. It is a stable material, strong and resilient. I also like that it gets a little bit grippier when wet, always a plus in a knife you might be using in inclement weather.
The blade on this knife was given a stonewashed finish, which is one of my favorite finish types. A stonewash finish is created by... tumbling the knife with pebbles. It is what it sounds like. In my experience stonewash finishes feel pretty low friction, and they are more resistant to corrosion than bead blasted finishes. Additionally the stonewash hides scratches pretty well, which helps keep the blade looking nice. The stonewash finish also keeps the blade from being too reflective if that is a concern.
The steel for this knife is CPM 3V. CPM 3V is a particle super steel, as I have said before, these steels are made with science magic. I'm not going to try to explain all of the specifics because I am not a metallurgist and blade steel is a surprisingly complicated topic. There is no one perfect steel for every knife. Each steel type has its own set of properties, and the choice of which properties are important to a knife is a key decision for knife makers. Additionally, the properties of various steels are affected by heat treatment (the ways that the metal is heated and cooled to control hardness) and heat treatment can even affect the crystalline structure of the steel and the ways that the compounds in the steel combine. So for the purposes of my reviews, science magic.
That said, I think it is worthwhile to discuss the characteristics of CPM 3V a little. CPM 3V is not a stainless steel, though it does contain 7.5% chromium, which provides more stain resistance than one might expect from a carbon steel. In terms of edge holding properties at the hardness used for this knife, CPM 3V is very comparable to CPM S35VN (which is the stainless particle steel the Difensa is made of). The biggest difference between 3V and S35VN (besides rust resistance) is toughness. 3V is roughly 3 times as impact resistant as S35VN. It is a very tough steel, appropriate for a knife intended for rough applications.
To sum up on the steel: CPM 3V is very, very tough, not stainless, and holds an edge well.
A note on the sheath:
The tester came with a Kydex sheath, which is one of the sheath options offered at no additional price. Kydex is a thermo-plastic, and the sheaths made out of kydex are generally form-fitting. I don't have a lot of experience with Kydex sheaths, I am personally partial to more traditional looking sheaths, but Kydex does offer some functional advantages. Kydex sheaths hold the knife in place by being fairly rigid and formed to fit the knife. This means that the knife can be pulled out quickly without needing to unsnap anything, but the knife is still held firmly in place. Plastic also is resistant to water and other environmental issues (unlike leather for example). The sheath performed fine.
Review:
Steel:
I found the performance of the CPM 3V impressive. I was actually the third person to get to use the tester. The first person stropped the blade to give the knife a very fine edge. The next reviewer did not sharpen the knife after his testing, and the knife came to me still holding a hair shaving edge. After the testing I subjected the knife to, the knife still held the fine edge. I didn't get too abusive with the knife, but I did try to use the knife a good amount in a variety of settings to get an idea of the performance.
My impressions of CPM 3V's performance as a blade steel were unambiguously positive based on my experience with this knife. I tend to prefer stainless steels myself (particularly living in the Pacific Northwest, and I don't know how corrosion resistant 3V is long term), but other than still having a prejudice in favor of stainless, I am sold on CPM 3V as an excellent choice for a blade steel.
Blade Finish:
As I stated earlier, stonewash is one of my favorite finishes. In the case of this knife in particular, one of the advantages of stonewash as opposed to a blade coating was demonstrated during head to head comparison. Stonewash has a lower friction coefficient than a ZRN coated blade, especially when wet. I'll discuss that more later in the review, but the finish is definitely a positive.
Blade:
I was not so thrilled with the blade shape overall. The rapidly dropping point serves to keep the blade thick pretty much the whole way through to the point. This makes sense as the knife is designed to be a hard use bush knife, not a slicer or combat knife, but it just felt kind of... frumpy to me. Frumpy is the best word I can think of. The blade didn't feel agile or graceful, it just felt like a sharp, somewhat pointy bar of metal to me.
I don't have experience with other blades with this sort of "bushcraft" blade style, so I can't say whether or not this knife blade was somehow less exciting than other knives shaped similarly, but I suspect that a lot of what left me cold about the blade would hold true for many bushcraft blades.
The blade is not a negative, it just wasn't a positive for me either. It was neutral.
Handle:
The handle actually surprised me. My first impression when I opened the box was that the handle looked boring. My next impression when I picked it up was that the handle felt square and boxy. My third impression was that the handle did not crowd my pinky, which I figured was at least one positive. I had low expectations for the handle at that point.
What surprised me was that when I actually used the knife it turned out to be very comfortable in actual use, especially during longer use. The handle, which I initially found less than welcoming, turned out to be very hotspot free. The only problems I had with the handle were actually more about the blade, the blade lacks a finger choil and jimping, which I felt limited the grips that were available to me. As long as I stuck to the handle I was fine, but for some of the whittling, trying to choke up on the blade was awkward.
So the handle was definitely a positive. The handle didn't wow me out of the box, but in use it became one of my favorite things about the knife.
Fit and Finish:
Pretty good. No real complaints. At risk of sounding repetitive, the fit and finish was not as flawless as the Fantoni, but nothing has wowed me quite like that knife. For the price range (mid-$200's USD), the fit and finish seemed perfectly adequate. If all of Ambush's knives come out that nicely finished, they will be doing well.
Introduction:
Weight: 8.8 ounces
Cutting Edge: 5"
Blade Height: 1.25"
Blade Steel: CPM 3V
Review:
Steel:
Blade Finish:
Blade:
Handle:
Fit and Finish:
