American Lawman CTS-XHP
Been a while since I acquired a new blade, nearly 11 months in fact. I’m a big Cold Steel fan; over the years I’ve bought nearly 20, starting with the Master Hunter (still a favorite), original tanto, SRK, a handful of Voyagers, California Drop-point, that neat little liner-lock whose name I forget, a bunch of Red River blades, and never had a complaint. They all cut, well, as advertised. Lately I’ve been following Lynn Thompson’s introduction of new steels and models, specifically the American Lawman in CTS-XHP, which features the Tri-Ad Lock. It arrived today, and I’ve already nicked myself. Usually I take a new blade right to the DMTs, but not this one. It’s hair-popping sharp out of the box. Carpenter describes CTS-XHP as an “air hardening, high carbon, high chromium, corrosion resistant alloy which can be described as either a high hardness Type 440C stainless steel or a corrosion resistant D2 tool steel. Possesses corrosion resistance equivalent to Type 440C stainless but can attain a maximum hardness of 64 HRC, approaching that of D2 tool steel.” It's a powder steel, like Crucible's S30V/S35Vn, which I love. The 3.5” blade is also coated with a DLC (Diamond Like Coating), black, very smooth. Not unlike the grey titanium-nitride-aluminum (or whatever) coating on my BassPro 110 in CPM154, which is very slick. Gunk just doesn’t stick. DLC coatings are amorphous carbon coatings that exhibit a high surface hardness and a low friction coefficient providing wear resistance. In Cold Steel’s video of AUS-8 vs CTS-XHP push cut comparison, slicing a LOT of hemp rope, the DLC coating showed hardly a scratch after +5,000 cuts. Good enough for me. The G-10 grip has no liners, and CS says they aren’t needed. I can't detect any flex by hand pressure. The knife is consequently very light, 4.5 ounces, and feels even lighter. It’s also quite thin, handy for slipping into a pocket. The G-10 has a good grippy texture, not quite as coarse as some. It came with a spare clip for the left side. I had to take the right-mounted clip off and squish it slightly in a vice, as it was so tight I couldn’t even force it over the seam of a jean pocket. Noted that the screws had a bit of blue Loctite, a thoughtful touch. Whoever put these together in Taiwan does a nice job. It’s quite a broad knife, and the drop-point blade is deep, with a shallow grind. Should be an excellent slicer. The lock-back is a proven design; the blade swings closed rather abruptly (hence the nick), but two-handed closing should prevent any future blood loss in that direction. This little knife is going into the rotation and I expect it will see a lot of pocket time. :)
Nice review. I'm liking mine too. I bent the front of the clip to clear a pocket seam. My only complaint. Enjoy your knife.
You can one-hand close the knife using several safe methods. Glad to see a good review of the knife. I am waiting on the exchange rate to come down and then I am going to buy one.
Thanks to your enabling earlier today DocT, I too am looking at the Lawman as a future purchase... ;)
Good to catch up...
Ben
Good to catch up...
Ben
Yeah, you too.
There is a video on Youtube of a guy who compares the older AL with a Spyderco Paramilitary 2. He (gasp!) likes the AL better! at least for his uses. I can easily open and close one of these with one hand and my examples of the Triad Lock are the smoothest knives of any type I own from any maker.
