An equipment related win! MIG upgrade.
For years the utility welding method in my shop has been stick. TIG is great for some stuff, and my little craftsman MIG does OKish on sheet metal- but when you need to put some amps into general steel work, it's hard to beat stick welding. Unless that is, you have a sizeable MIG machine- especially if you're doing things like dry-welding billets by arcing up all the seams first, it's a lot faster than stick welding.
I went looking for one recently, and came up with an AIRCO CV300 II Migatronic welder. That's a big old transformer based machine, in this case out of a Seattle shipyard. It was set up for spray transfer welding with 1/16" dual shield wire! I got it for $300. The catch: it's a 3 phase only machine.
There are people who have converted 3 phase welders for single phase use, most notably a fellow named Dave Kamp from the various welding forums. I figured I might try that; at any rate, my VFD puts out only up to 3 hp (far below the 35 amp necessary input for the welder) and research lead me to believe that a VFD can be damaged when feeding a welder.
Fortune smiled upon me, and a Phase Perfect 10 hp digital phase converter basically fell into my lap. This is not a static phase converter, but a quite expensive box that digitally and efficiently synthesizes a perfectly balanced third leg of power. What literature and chatter I could find online indicated it would work fine to power a welder.
Well, I finished wiring everything tonight, and powered up- and the welder works great! All I had on hand was the argon for my TIG setup, so the arc was a little gruff, but I think tomorrow when I go get some 85/15 mix that will improve.
Just thought I'd share that, as a +1 for Phase Perfect if anyone should consider one.
Plus, now I have a power supply for any mechanical power hammer up to perhaps 150 lbs. that I might find...
I always thought that VDF's were meant solely for motors.... I am glad to see that you found the solution for powering 3ph welding equipment from 1ph. You now just need enough 1ph juice to feed it!
What do you plan on welding with that beast? I also own a 3ph industrial MIG welder (bought used from a construction equipment sale) but I got lucky and have 3ph power where I use it. Needless to say, I have never used it even to half of its rated power....
Make sure the dual shield wire will run correctly on 85-15. There are some wires that will run on 75-25, 100 co2, one or the other, or both. 1/16" dual shield is really meant for thick sections. I generally stay away from anything other than flat or horizontal with a wire that dia. The puddle will be big and runny. I typically like .045" for all positions.
Kevin, I took the dual shield wire off, and put in a liner and drive wheel etc. for .035" wire. I first brought the machine to the fab shop, with utility 3 phase to test it out, and did try it on spray with 75-25, which seemed to work quite well at high voltages. The .035" is more useful for the stuff that I tend to weld, though. I'll probably get some stuff for .045" if I see the drive wheel come up anywhere for sale. It's discontinued AIRCO stuff so it's hard to find. Might try making one on the lathe some time...
Mikel, mostly billet work and some occasional fabrication. It's more welder than I need, but it was $300 as opposed to like $2500 for a MM 252 (nice, but less welder) so I went overkill- happily.
