I recently did some experimenting with a blade of 1095. Nothing fancy, just a dropped edge blade with a convex grind and an almost symetrical spear point. The experimental part was exploring the possibilities of a microstructure I had not used before. The contest and give away parts are the blade will go to the first member of less than 4 years to guess the heat treatment and/or microstructure based only on the information given below. If no body has guessed after 100 posts, I'll keep it.
The micro structure has a higher amount of carbide than the usual quenched and tempered heat treatment. Toughness is measurably less than tempered martensite of the same hardness. I'm going to say here that ductility will be the same or better than martensite, but I'll have to check and be sure.
Edge holding tests were done by cutting cardboard and checking the edge after a certain number of cuts. The first round of cuts was roughly 20 on 2" wide strips, using a marked 2" section of the blade (5.5" overall). After this it would still shave hair off my arm. Steeling of the edge was also used, mostly because I was curious about it, as I don't use it often. The next round of cuts was roughly double the previous one, 20 on the first, then 40, then 80, and so on. The edge was checked after each round and steeled lightly with 3 to 5 passes per side. The edge angle was 18 to 20 degrees, applied with an 80, 120, and worn 180 grit belt, then finished by power stropping on leather on the 1x30 sander. The leather was loaded with white compound. This was the first time the knife was sharpened, which is the reason for the very coarse belt sequence.
After the second round (88 cuts), the edge would no longer shave. However the steeling returned it basically to it's beginning sharpness. This also happened after round 3 (188 cuts), and round 4 (415 cuts). In these rounds the edge recovered to basically original sharpness after light steeling. After round 5 (830 cuts) the edge was steeled and, though still pretty sharp, it was noticably duller than before. This is the end of the cutting, as I'm out of cardboard, and my hands are tired. After rounds 2-4, the edge would still slice paper, but would not shave my arm. So after cutting roughly 1300 inches of cardboard, a quick steeling was all that was required to restore the edge.
So any guesses? The post count goes from 2 to 102.
