- Feb 5, 2024
Grinds are probably the most challenging part of the knife making process for beginners. This is my two cents for any new makers.
File Your Plunge Lines First
Not only will you have clean plunge lines, you will have something to use as a reference while grinding.
Learn to Freehand, But do it Right
Yes, jigs are essy, and are a great option. However, you can get more or less the same effect as a jig by resting the blade on your table (I forget the term for the thing you put your steel on when grinding). If you want to, you can get a cheap jig and set it to the furthest depth you will grind to. Grind the same way you would freehand, but with the blade in the jig. The jig acts as a safety, while you learn the basics of freehand.
Don’t Use The Floppy Part!
As tempting as it may be, DO NOT USE THE FLOPPY PART OF THE BELT unless you want that type of grind. It is not faster, it’s less precise and will ruin your grind.
Trust Yourself
I’ve ruined a dozen or so blades because I kept trying to correct minor errors in the beginning stages of grinding. The uneven bevel lines will work themselves out over time, and worst comes to worst you can file or sand them out.
Trust Yourself
