An Opinel saves the day
I got a great demonstration yesterday in the importance of carrying a knife, the ability of a traditional pattern to hold its own with a modern, 'hard-use' knife, and in particular, the ability of a No. 8 opinel to punch above its weight. I was traveling with friends to a ferry on Lake Ontario, planning to make the crossing to Wolfe Island for the evening. Having been late to leave the house, I decided to take my longboard instead of walking (longboarding, for all you who've never seen it, is like skateboarding, but very, very fast). Zipping downhill through Kingston, I misjudged my aim when going through an intersection and found myself pointed directly at a sidewalk curb. Not being terribly aerodynamic, I didn't want to try my luck at flying, so I jumped for it before the curb could launch me. I landed just a little wrong, felt a hot jet of pain shoot up my ankle, and sat down hard.
I wasn't sure just what I'd done to myself, but I'd gone far enough that I figured I might as well push on to the ferry and enjoy my evening. It quickly become clear, though, that I wasn't going to be able to walk around all night on that ankle; it was swelling up pretty good, and putting any weight on it was becoming impossible. I did make it to the ferry, but without some improvement in my situation, there was no way I was going any further that night.
I believe in being prepared, though, and I had a couple resources: a first aid kit and a No. 8 Opinel. I wrapped my ankle good and tight with a tensor bandage to stabilise it and keep the swelling down, but it still hurt like crazy to walk. Lucky for me, I also found a stand of saplings by the lake's edge, and I set to work finding myself a cane. Having found a two-inch sapling sturdy enough to bear my weight, I set to with my knife, starting off with as deep a wedge as I could get and then continuing to cut thin shavings from both sides of it. As I worked, I thought about all the friends who'd scoffed at my Opinel's thin blade, wooden handle, and simple lock. "It'll never stand up to a real job," they'd said; "When you need it most, that blade'll snap, or the lock will fail. That knife's a cheese-cutter and little else." Well, that thin blade was going through the green wood as if it really was cheese. I wasn't sawing at the wood, or trying to pry at it, or twist the knife into it; I was using it the way a knife is meant to be used, and by golly it held up its end of the bargain. Before long I'd felled my sapling, and the carbon steel blade was still plenty sharp enough to zip through the branches and shoots on the sides. I walked back to where my friends were waiting with a good, strong walking stick and a good deal less pain in my steps.
I just wanted to post this story as a reminder about what traditional patterns can do if you use them the way they ought to be used, and also as a thank you to all the folks who've been talking about this for years here. I've been soaking up your wisdom, and it's paying off. I want to thank jackknife in particular for his oft-repeated advice to sharpen your knife every morning before you go out the door, because you never know what you might need to cut, or where, or when. Truer words were never spoken, and when the time came to do something a little more important than opening letters, my knife was sharp enough to do the job.
Mac
Great read, the Opinel definitely has an attraction.
I was given one by one of our great members here and I have been using it quite a bit. It finds it's way into my pocket when I least expect it. I am supposed to send it on to a friend, but I'm having a hard time parting with it.
There is a beauty in simplicity and the Opinel is the simplest.
You think that worked well? Just imagine if it had been a Zero Tolerance or a Sebenza! It would have done the same exact thing!
Amazing how a sub-$20 knife with realitively "antique" technology works so well. It sounds like I need to buy an opinel! I think sometimes people outside this forum forget that our forefathers used traditional style knives in ways that would make those with their super steel tough-guy knives shudder.
Good on you OP. Let others take from this story an additional idea, one taken from survival teaching. You can carry all the gear you can hold, but if you don't have knowledge to use it, you're sunk.
Nice story.
I got my first Opinel on a whim on a trade for bike parts. I had no expectation and was blown away.
While I find them ok out of the box, I think they go from good to great with some DIY Moxie. The blade can be polished out to remove the grind marks, the blade shape can be tweaked with a bit of file work, the lock ring can be filed to make it even more secure and the handle can be modified easily.
Here is my #10 drop point easy open. It's my back up knife an is with me every where I go pretty much. Exactly the same size as my Buck 110 but more versatile due to its low weight.
opinel #10 by Pinnah, on Flickr
In terms of toughness, a recent thread here revealed that they are as tough or tougher than any other.
I find there brutal, even crude simplicity to be good for my greedy materialistic soul. The grind is amazing for cutting wood and it simply performs. Any knife lust I have beyond this is just that - lust.
Johnny, keep the knife for heavens sake. It's earning it's keep, ain't it?!?!
Great story and reminder, glad to hear you're alright. I always carry a blade of some sort and while I don't sharpen every morning I usually sharpen my main EDC blade every once in a while but no matter what main blade I'm carrying here lately I haven't got up in the morning without putting my small Razor sharp Opinel 06 on my person. I love Opinels particularly the 06 it's small enough to not be a hassle to carry but locks up tight and takes a downright scary edge and makes a fine backup knife.
first, great story Mac...and good luck with the ankle. but also...this post is a bit ironic for me. i just bought my first opinel today. i lost my Vic Farmer. i've been looking for a week and can't find it. i finally tweaked...i couldn't handle not having a knife on me. went down to my local outfitter to see what they had. picked up a #8, with the tapered handle. i've always been kinda curious. i've played with it a bit tonight and i am impressed for a $20 knife. looking forward to using it more. hopefully, i won't have to make a cane...or a splint. ;)
Opinel's are the true wonder knife. Such a lightweight little thing, with as mentioned antique design, funky looks, yet huge capability. It will cut with the best of them, and stand up to abuse well. People forget that this knife was born in a peasant working area, where people didn't have much of what we call today, disposable income. Any tool had to work. Really work, without breaking. In it's early years, this knife was made for farmers, day laborers, and tradesmen. Not the gentleman hunter or picnicker. This is far, far more knife than a picnic knife.
Let me tell you how rugged this knife is.
When I first got into Opinel's, they were like 5 dollars for a number 6. I bought it as a cheap standby for the dirty jobs I didn't want to ruin the edge on my Buck or SAK on. So I used the ever loving heck out of it. Leaned on it, abused it, and came away really impressed. I started to have huge rtespect for the knife and maybe even did a little bragging about it. Well that led to the "test."
A bud, Danny, expressed some doubts that a little knife this light could be worth anything beyond a picnic knife. Sound familiar? He looked at it and said it would break soon as you leaned on it. I stood up for the little slicer, and we made a bet. The bet was, he couldn't break the knife by hand on anything he needed to cut. I have to admit at this point in the story that we'd had a few beers. So Danny goes down the basement and comes up with some thick heavy manilla rope. He goes and saws away on an angle and the Opinel slices right through the rope. He does it again, same result. Then he gets a hardwood dowel and cuts into the dowel at a 45 degree angle and is twisting the blade. The knife goes through the dowel. Cuts it off clean with very little effort. It went through so fast, Danny almost takes a slice of his thigh. By this time, he's holding the knife out and looking at it, with what I can guess is the beginning of respect. I should say here, that Danny is 6' 4" and about 250 to 270. Big strong guy and works out. So far, he couldn't break the Opinel.
By now, we're both curious, about in a real emergent how much can you lean on an Opinel. Danny takes out his wallet and hands me a five and says "Let's see."
We put the blade of the Opinel halfway in a vise and clamp it down. Danny puts on a heavy work glove and starts to bend the knife over. The blade is flexing, bending, and Danny is surprised at how much pressure he has to push down with. Finally , at past 45 degrees, there's a snap, and the blade breaks. But it breaks off clean even with the vise jaws, leaving half the blade still usable and foldable. The action of the pivot was unaffected, and the joint still had 100% integrity, with the locking ring still working. It took a 6 foot 4 inch 250 pound guy and a vise on a heavy workbench clamping the blade, to break a little number 6 Opinel. The next day, Danny went out and bought a number 8 Opinel. Now a bit over thirty years later, Danny is still a fan of Opinel knives with a selection that he uses for edc and fishing.
Not bad for a lightweight little knife.
Carl.
Great stories! Opinels have one of the best, if not the best, geometry for cutting.
I am SO pleased and relieved to find others who love Opinels. I love and lust for bunches of knives but there's just something so elegantly simple about the Opinel design. And, the best part is bang for the buck weighed against terrific quality. They are priced so affordable that you can easily purchase and mod one as a gift for, say, a nephew's birthday or as thoughtful a parting gift for a neighbor's western fishing trip ... and they are so much fun to mod! And, they are so much fun to sharpen! (I agree with the full convex approach, as avoidspam mentions.)
I offer best wishes to MacCairnie and hope he is recovering nicely. And thank you for posting so that I could discover others who, like me, just have a sincere soft spot for the beloved Opinel.
I remember having one when I was a kid. my first "locking" knife as it were...wonderful tool on the farm.
Things I hate about the Opinel
I hate when folk say:
"For $Xs it is only a beater"
"For that price I do not care if I loose it"
I hate it when repect for an object depends on its price not on its quality as it fulfills its function
What I love is that the Opinel turns that attitude on its head
I worked in rural Brittany in the summer of 1981
I worked as an electrician and carpenter
Every farmer and worker had an Opinel in their pocket
It worked full time....
I was given one as a going away present
Which I still have
For the past week or so I have been carrying nothing else but my slightly modified Opinel 6.
Just feels nice to carry a knife I can easily replace when lost by going to a hardware/outdoor shop instead of ordering online and pay twice the actual costs to get it.
And man, is this a robuste knife...
I'm a flexographic printer by trade and at my first job we were issued with Opinels.
You won't believe what our knives had to go through:
- Cutting plastic bindings(the heavy stuff)
- Cutting thick cardboard boxes.
- Cutting thick and sometimes abbresive plastic foils
- Scraping ink from all kinds of machine parts.
- Being covered in ink and/or solvents
- Some light prying
The knives were all "au carbon" and I had to sharpen it very regularly(but oh so easy) however the Opinel itself never failed.
Terrific simple working/EDC knives.
If you've not yet seen it, you might appreciate the short online video "The Story of Stuff"
It takes 20 minutes to watch. Suggest watching while holding a good value knife like the Opinel in hand before making other knife purchases.
Not enough can be said about the simplicity and value of the beloved Opie. I enjoy spending time on these "kit knives", turning them into something worth looking at as well as using.
Reshaping the blades, handles, decorative filework and so on while still having at least a decent grade of steel for routine tasks.
While I would not want to lose any, I do give them away after a while. I meet nice folks in the woods and on the rivers and they often don't have a decent tool. They always seem happy and it gives me an excuse to get another to mod.
I'll not pretend they are the solution to all things, but for general everyday tasks like food prep, cutting cordage, casual gutting and fillet work as well as whittling, they are impossible to beat for the price.
I EDC an Opinel No.8 Carbon and it definitely no lightweight when it comes to performance!
I modified mine with an easy-open notch.
I am a big fan of Opinels, I've been carrying them for 20 years #8-#10, I find the #9 is best for me, #10 is my camp knife, this one (#9) carried as my EDC work knife for 7+ years, would still carry it everyday if I had not complicated my life with other knives.
Some Opinel photos in use around the world
