- Nov 29, 2005
Several years ago, I learned from some instructor about how to use a stone axe-head of the variety that one sees in paleo-Indian museums in the desert Southwest. It's different from how one uses a steel axe. With the steel axe, one can lift it up to head level, or much higher still, and use a high-impact, long swing.
I was a little surprised to learn that that's not how one uses a stone-age stone axe. Instead, I was told, what you do is chew away slowly at the wood with a long series of little chops, with swings only a couple of inches long, at the maximum. I was given the opportunity to try that, and was surprised at how well it worked--and also at how quickly such minimal-length swings let the axe eat through the wood being chopped.
It occurs to me that if one adopts a similar lots-of-little-chips approach--and the patience that implies--one could get somewhat-respectable chopping results out of knife blades that are not usually associated with chopping. I'm pretty confident, for example, that you could cut down a decent-sized pine that way in less than an hour with a standard US military issue Ka-Bar, and probably even with a pilot survival knife. It'd certainly be more time consuming than with a dedicated chopper like a khukuri or a Ranger RD9, but I think with a little patience you wouldn't find yourself out of the chopping game even with a fairly-heavy five-and-a-half-inch blade.
