- Jun 26, 2007
Hi all,
another italian traditional knife today, the anconetano. This knife is from the Italian Adriatic Sea coastal area, and was used mainly by fishermans
This particular knife was made by Giovanni Nino Nista from S. Benedetto del Tronto, specs are as follows:
Total length 195mm
Blade length 85mm
Steel AISI 420
Blade thickness 2mm
Wheigt 54 grams
The handle is one-piece cows horn
The blade is thin and straight pointed, usefull to work fishes
The original handles shape is curved
The blade spring is particular someway, in fact is external to the handle
As I previously said, the anconetano was used mainly by fishermans. The tang of the knife is shaped to help the fisherman in the nets maintenance just in case
Some cutting trials, not bad at all
Hope you like it,
Ciao
Alfredo
Total length 195mm
Blade length 85mm
Steel AISI 420
Blade thickness 2mm
Wheigt 54 grams
Hope you like it,
Ciao
Alfredo
