- Aug 24, 1999
Well, got out to the forge this weekend, finally started to beat on some worthwhile steel (Got some 1095 from Admiral and MAN! Is it a step up from the Home Despot re-bar I've been practicing on!!)
So, I'm out practicing my scrolls, and I decide it's time to start on a knife. My first forged blade! Ooh, I still get chills...
It turned out to be a little skinner, about 3.5 inches of blade to it, with a fairly fat belly. When I get a chance, I'll try to post a pic.
Then, I got the bright idea to practice my welding. So I turn up the gas to the forge, and put a nice "J" on the end of my stock. I let it heat up again, and sprinkle it up with Borax. All according to Hoyle, thusfar. So I close it up a little more, and throw it back in the fire to get the final heat for welding. Well, I bring it out, and put more Borax on it, and then I line it up to smack that weld down and close it up. The sequence of events plays out something like this:
1. Line up steel.
2. Raise 3lb. hammer.
3. Swing and strike the steel squarely.
4. Watch molten Borax shoots out in a damned-near 360-degree arc from the weld, spattering off of my pants, then fence, the forge, and my carport.
5. Notice a sharp, burning pain in my hand (at this point, I mistake it for a blister having broken).
6. Set the steel back in the fire.
7. Set down hammer, and begin the JEEZTHATHURTS dance...
For whatever interesting reason, I have discovered that Borax, when it hits skin, basically burns in, then seals itself in. So that what you're left with is a tiny speck of 700-degree Borax, buried under your skin. By the time I could dig it out, though, it had already stopped burning, after cauterizing the surrounding tissues, which is, in retrospect, a good thing (have I secured my title as Most Likely to Find the Silver Lining in an Amputation, yet?).
Still, it was a good weld. Clean, no lines, and I couldn't tear it apart. So it wasn't a total waste!
Anyway, a question: Is it alright to quench 1095 between workings? I thought it would be, but the next time I heated it, after working it and quenching it the day before, I noticed that it wanted to crack a bit. Should I anneal it, after I quench it? Or should I be able to jump straight back into heating for work again? Or, alternately, should I just set it aside to cool, once I'm done working with it?
Thanks!
1. Line up steel.
Thanks!
