- Apr 10, 2000
Knife steel chart 3.60 is on the google play.
Added SD card support for Android 2.2 and higher. Application can be moved to SD card, however the data files must remain on the phone, which requires about 1mb space on the device. Use Android Settings/Applications menu to move app.
For the moment, moving all data to SD card would require dropping support for old android devices below 2.1, and since there are few hundred users using the app on those, I can't do that.
Based on your Android OS decision, app will be installed on the phone or SD card. After that you can move app between those two using Settings/Applications menu. Simply copying the app to SD card will result in a crash.
Let me know if you encounter any problems.
