Seeking some advice.
I have a blade with a rather useless saw-teeth section on the top of a blade (a bit like the USAF pilot knife serrations but deeper and thinner). This saw was intended to cut wood but I have little use for it as I have a rucksack and it just outcuts everything.
Steel is 440C.
Should I use an angle grinder with reinforced cut off wheel to just slice off the whole section. OR should I use the same angle grinder with a grinding wheel to grind it off slowly. OR should I use a hacksaw to cut it off. I know that there are tempering issues if I use the grinding wheel so that I why I am soliciting information. Can some you with practical experience advise me here?
Thanks
Steel is 440C.
Thanks
