Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
tacmedic45 said:I am not sure i could survive without my angle grinder anymore. my bench grinder crapped out about 6 months ago and i don't even miss it anymore. I read an old article on D.E. Henry awhile ago and he used an angle grinder allot for profileing and setting up the bevels. I figure if it worked for him it oughta work for me.
Yes, Mike, I would like to see whatever you can show me. The more i learn, the better. What grits (at minimum) should i be using for sanding?mikxx1 said:Right now I use an angle grinder for all my rough profiling. I use a zip disc to cut most of the excess off then a grinding disc to smooth it out. Depending on the profile ...I also have a spindle sander to get the finger grooves etc. nice and smooth. I find it works quite well. Maybe not for a full time maker as this is a little more time consuming than most other methods. I also would find it a bit crude to use for the bevels but I guess you could start them off with itif you hav eno other way. I have some pics of profiling... if you'd like to see them send me your e-mail. They are too "big" to fit on the alotted space per picture that I can use here. I could also show you my disc sander which I use for the bevels (home made).
Mike
bzzhewt said:Yes, Mike, I would like to see whatever you can show me. The more i learn, the better. What grits (at minimum) should i be using for sanding?
Also, where to get decent files?
