Quality dealer.
I also have an old Honemaster, works good but you can get by a lot simpler as Ed suggested. My buddy uses one of those clips that hold office papers together.I've used a Buck Honemaster (no longer made) for several decades. The lips are a bit worn bit it still works fine. A search for Knife Angle Guide will turn up several by various makers. A cheapo alternative is to tape a coin on either side of the blade to achieve the angle you want.
DMT's Aligner clamp is designed so it can be used with a bench stone, with extendable arms adjustable for angle and sliding on the table alongside the stone. Used that way, there's no chance for the guide to be worn down or abraded by the stone itself. An example video below. And the clamp is made of a tough FRN-like plastic, which minimizes the risk of marring blade finishes, so long as the clamping surfaces are clean. Another advantage is, you can use the full surface of the stone for sharpening, without worrying about the guide coming off the stone. That also allows for a more natural, sweeping sharpening stroke, as would be used freehand with the same stone. The device is a pretty good training aid for learning freehand sharpening, used this way.How are such devices not sacrificial by design? How long does the initial angle setting last?
Ah, that's the one I was thinking about when I said Norton made one.DMT's Aligner clamp is designed so it can be used with a bench stone, with extendable arms adjustable for angle and sliding on the table alongside the stone. Used that way, there's no chance for the guide to be worn down or abraded by the stone itself. An example video below. And the clamp is made of a tough FRN-like plastic, which minimizes the risk of marring blade finishes, so long as the clamping surfaces are clean.
That Aligner clamp was the last guide I used before transitioning to freehand. It's kind of what made things 'click' for me, for the feel of it with a bench stone.Not bad...and I'm an admitted DMT fan of sorts. I've gotten used to free-handing though. Takes a while to train the "muscle memory", but once you've gotten the hang of it, as sharp as you will is possible.
