- Sep 3, 2006
So what is the deal with a flat lock face vs. a radius lock face on a liner lock or a frame lock?
AFAIK, Chris Reeve, Spyderco, Benchmade, and a few others use a radiused lock face. Kershaw, ZT, Strider, Hinderer (I think) use flat angled lock faces. I made my own little model out of some pieces of paper that I cut up and pinned the paper lock bar in place and as it travels it seems that the only good way to make it contact the blade tang the entire time is to cut a radius. With a flat angle the lock bar only touches the blade tang entirely at one point. Before that point and after that point the lock bar only touches with it's corners. In the past I have had a few knives that I have been able to put pressure with my hand on the back of the blade and then watch the lock bar slide across the blade tang (lock face) in the direction of unlocking. I have seen this only on knives that have had either poorly radiused tangs or flat angled tangs. It seemed that it would be due to only a corner touching the blade tang and physics. The fact that you put pressure on the blade which then puts pressure on the lock bar and then if it is not square, the lock bar slides in the direction opposite the force.
With all that said, why do people make liner locks and frame locks with flat angled lock faces? Recently I heard that Strider changed to that from a radiused face. Seems like it's going backwards to me.
This is not a bashing thread on Strider or any other company that uses the flat angled lock face. I'm just looking to understand why they use it instead of a radius?
If you fix a point (the non moving end of the lock bar) and you move the other end of the object (the locking part of the lock bar) it moves in a circle. It creates a radius. So shouldn't the lock face match the radius of the moving bar?
I will post an illustration later for anyone that doesn't understand.
Thanks!
Thanks!
