- Jan 16, 2002
I thought I would confirm an earlier post about anhydrous borax. I have the 20 mule borax and tried to weld some cable without much success. The borax when applied would fluff up and not cover very well. I took a coffee can and filled it about a third of the way and used a rose bud to melt it (it took a little while) then I used a large brass rod to crunch it up again (about sand size). I used this material again on the cable and it worked great, no fluffing or dropping off. You probably could use the oven but I would go as high as you can so that it melts and then grind it up. I will use the oven the next time. Just thought I would confirm and pass it along.
