- Dec 4, 2001
I finaly got ahold of a variac, 0-150v, and built an anodizer using Bob Warners plans, http://www.warnerknives.com/anodizer.htm
It works, but I am now blowing fuses in a second or less. The rectifier is rated at 6 amps, and the variac has a fuse between the output ac and the rectifier. The fuse that was in it when I got it seemed pretty heavy, lot heaver than 6 amps and worked for a while but then blew. I put a 6 amp fuse in and it blew almost imeadeatly.
I've wired it up temporarily like the first diagram, and use a cheap volt meter to check leads out till I'm satisfied everything works rite then I'll wire the volt meter in for a display. Also I tried a split hook out of ti, to hang the linners off of. Aparently that didn't make good contact, so light pressure with a screw driver made contact and the TSP solotion started boiling around the test piece, that's when things started blowing fuses. I tried gator cliping directly to the test piece and it too blew fuses pretty quik. I understand that the solution is suposed to boil? Also using a large mouth mason jar to hold solotion and anode and cathode, using plastic canvas to hold the ti cathode inplace.
What am I doing wrong? Do I need a heaver fuse going to the rectifier?
Thanks,
Will
Thanks,
Will
